Discuss
Additional parts included in the 505471P Timer Kit for Electric Dryers
 in
Dryer Repair
I recieved a 505471P timer kit to replace the original timer, on my dryer. It includes a Jumper wire which
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Additional parts included in the 505471P Timer Kit for Electric Dryers
  #1 (permalink)
Old 08-26-2008, 01:56 PM
James Albert James Albert is offline
Junior Member
James Albert is on a distinguished road
Default Additional parts included in the 505471P Timer Kit for Electric Dryers
Model Number: LEA60AW   Brand: Amana   Age: 5 - 10 years
I recieved a 505471P timer kit to replace the original timer, on my dryer. It includes a Jumper wire which has a 1/4" terminal, on one end, and a 3/16" terminal on the other end. The instructions state to connect the 1/4" end, of this jumper wire, to the supplied connector (#21091) and then attach the 3/16" end, of the wire, to the timer. The instructions then tells you to attach the wire that you removed from the timer terminal to the other end of the supplied connector but the supplied connector has 1/4" ends, on both sides, so the wire that was removed from the timer, which has a 3/16" end will not attach to the connector. Is it necessary to attach the connector in the circut? The original timer did not have this connector and it ran for almost ten years. What is the purpose of this connector?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-27-2008, 02:02 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi James,
If you can post the copy of the installation instructions for this timer it might help better.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Electric Dryer Timer replacement uscgham Dryer Repair 3 08-16-2008 04:53 AM
Electric Dryer timer replacement chicks66 Dryer Repair 1 08-15-2008 08:18 PM
Admiral Electric Won't Start - replaced parts... read sixthsphere Dryer Repair 8 04-25-2008 10:27 PM
Additional Oven Error Codes indydoug Oven Repair (including Ranges and Cooktops) 1 11-16-2007 07:35 PM
dryers mommadogg Dryer Repair 0 11-04-2007 12:32 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
