Morfeo
#1 Posted : Monday, August 25, 2008 12:05:58 PM(UTC)
Morfeo
The AUTO setting of the timer won't advance and won't shut off. For any other setting it works. I mean, I can hear the ticking sound and if I use the Timed setting it will advance and it will shut off as normal.
Within the AUTO setting, if I manually advance the dial to the Cool Down mode, from that point on it will resume ticking and will advance until the OFF position and will shut off.
I already removed and cleaned the moisture sensor inside the drum but didn't make any difference.
It all started like this: the Dryer was working fine. It was drying a heavy load of wet blue jeans... and suddenly it stopped. It seemed as if there was no power going through. I read here that it could be the Thermal Fuse. I by-passed and still wouldn't work. I plugged the thermal fuse again. I openned the door and closed it... press the Start button and I heard a humm noise. I removed all the cloths and it started working!!
I put half the load and it worked but with a very loud grinding noise.
I opened it and found that the felt pad was broken. I replaced it and the drum was working smooth again... but ever since the dryer will not shut off in the AUTO setting.
Any ideas?
Morfeo
#2 Posted : Tuesday, August 26, 2008 5:50:00 AM(UTC)
Morfeo
Just a follow-up...
Yesterday, when I got home I checked the little board that integrates with the moisture sensor... and it was loose!!!!
I inserted it tightly... and the AUTO function now works!!! Aleluya!!!!
Thanks to the others who suggested to check this.
#3 Posted : Tuesday, August 26, 2008 7:43:48 PM(UTC)
Good job!
Whirlpool dryer WED7500VW1 won’t turn on (Dryer Repair)
by tryingmybest 11/15/2023 4:40:47 PM(UTC)
Whirlpool dryer wire (Dryer Repair)
by Guest 10/20/2023 10:51:08 AM(UTC)
Whirlpool dryer heavy load turning (Dryer Repair)
by Guest 3/28/2023 5:58:08 PM(UTC)
YWED7500VW0 - Looking whirlpool dryer belt access procedure (Dryer Repair)
by Toronto_18_2703 11/4/2022 12:46:25 PM(UTC)
Whirlpool Dryer Knocking Noise (Dryer Repair)
by Guest 8/31/2022 5:01:42 PM(UTC)
Whirlpool Dryer sensor light on and never starts (Dryer Repair)
by CPepe 8/27/2022 11:48:56 AM(UTC)
Whirlpool Dryer WGD5300SQ0 taking too long to dry (Dryer Repair)
by aryan 4/10/2022 3:24:26 PM(UTC)
Whirlpool Dryer Model# W10151592A (Dryer Repair)
by Ssuarez 2/28/2022 4:22:11 PM(UTC)
Whirlpool dryer WED9500TW1 (Dryer Repair)
by Herm404 12/18/2021 12:39:46 PM(UTC)
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 12/9/2021 6:57:53 AM(UTC)
Whirlpool Dryer Fan Not Working (Dryer Repair)
by kkknie 11/21/2021 12:09:24 PM(UTC)
Whirlpool Dryer WED5790VQ1 (Dryer Repair)
by Guest 10/22/2021 3:39:17 PM(UTC)
whirlpool dryer codes persist (Dryer Repair)
by JMM12 7/30/2021 4:52:44 AM(UTC)
whirlpool dryer stops on sensing (Dryer Repair)
by Guest 5/16/2021 7:46:23 PM(UTC)
Whirlpool dryer---need to hold start button several seconds (Dryer Repair)
by pjlarivi 2/13/2021 10:44:25 AM(UTC)
