I replaced the touch face interface #8558753 on my dryer and it worked five times before the problem appeared again. When I press control on, nothing happens. If I switch the cycle switch from heavy to casual and back to heavy the indicator light shows 40 minutes. I then move the switch to normal and it says 34 minutes. When I press the start button nothing happens.
I tried to enter the test mode using more time less time as in the instructions and nothing lights up.
Could the interface be defective or do I need to order the control board Ap3775548?
Thank you,
Rich Iannelli
