JamieM
#1 Posted : Saturday, August 23, 2008 4:51:59 PM(UTC)
JamieM
I want to replace the belt in my dryer but cannot find a repair manual. I need to know how to open the box to gain access to the area. The motors turns, dryer heat is on, but the drum won't turn. Exhaust hose is clean. Noises normal. Any help would be appreciated.
JamieM
#2 Posted : Wednesday, August 27, 2008 9:39:31 PM(UTC)
JamieM
Model Number: FDE437GHS0 Brand: Frigidaire
Thanks for the advice to replace belt. Put the dryer back together with no left over parts and no unconnected wires. Plugged into wall. Turned ON, no response. Rechecked the Wires and breaker. Turned ON, no response. What do I do now? Is there a reset button some where?
JamieM
libertyappl
#3 Posted : Thursday, August 28, 2008 5:14:34 AM(UTC)
libertyappl
Double check the wires to the door switch, if those are connected good it will not start. Also the plastic connectors that you snap together make sure one of the prongs aren't bent over a litle not going into the slot they are supposed to.
SublimeMasterJW
#4 Posted : Thursday, August 28, 2008 5:34:00 AM(UTC)
SublimeMasterJW
Remove the tub:a wpdcabinet.jpgIt is hard to read but the thermal fuse it in the upper right hand corner. If it is open then the dryer will not run.It is rather small about the size of a dime.
SublimeMasterJW attached the following image(s):
JamieM
#5 Posted : Monday, September 1, 2008 9:30:32 AM(UTC)
JamieM
Thanks-you guys,
It was the door switch. Dryer works like a charm.
JamieM
Replaceing Belt (Dryer Repair)
by JamieM 8/23/2008 5:00:31 PM(UTC)
