bigmatt
#1 Posted : Thursday, August 5, 2010 4:47:10 PM(UTC)
bigmatt
hi guys... i need some help.i have a kenmore gas dryer the igniter and gas comes on about the first 3 times and then won't come on any more.the igniter is new.i tested the gas coils with a tester and they were fine.the flame sensor and thermal fuse tested with good continuity also.but the thermistor tested at 3k on the dial on the multitester.should it be testing at 0....getting frustrated trying to find the problem.does anyone think the thermistor is crapping out...any help much appreciated
matt
tejohnson44
#2 Posted : Thursday, August 5, 2010 9:45:03 PM(UTC)
tejohnson44
Gas coils wear out and overheat, then they won't work right. Thats what your symptom sounds like. Replace the coils, their cheap.
bigmatt
#3 Posted : Friday, August 6, 2010 4:08:24 AM(UTC)
bigmatt
johnson...thanks for the reply i appreciate it.i'll try new gas coils.hopefully that will do the trick.
matt
LG Dryer Heater Thermistor Error (Dryer Repair)
by Guest 11/16/2022 8:37:57 AM(UTC)
Bad fresh food thermistor? (Refrigerator & Freezer Repair)
by barlav 10/1/2022 5:01:58 AM(UTC)
How do I access GE Evaporator Fan, coils, thermistor, etc (Refrigerator & Freezer Repair)
by Yari 8/4/2022 1:48:47 PM(UTC)
LG WM3050C thermistor/heating element help (Washer Repair)
by Guest 10/2/2021 5:29:07 AM(UTC)
Viking Thermistor Problem (Refrigerator & Freezer Repair)
by TDK-2020 10/21/2020 8:52:41 AM(UTC)
Maytag MRT311FFFZ00 thermistor chart & diagnostics mode (Refrigerator & Freezer Repair)
by scottaobe 2/1/2019 8:35:11 AM(UTC)
NEED HELP replacing THERMISTOR & FUSE assembly (Washer Repair)
by leastam 1/28/2019 2:06:26 PM(UTC)
GE Side by Side Thermistor Locations (Refrigerator & Freezer Repair)
by AlkiRich 1/3/2019 9:31:00 PM(UTC)
whirlpool GEX9868jt2. Was getting E1 error. replaced thermistor. Still getti (Dryer Repair)
by Garyatmaui 11/16/2017 12:19:47 PM(UTC)
how do i check the thermostat and thermistors (Refrigerator & Freezer Repair)
by ropeke 2/27/2017 2:25:42 PM(UTC)
E71 Outlet Control Thermistor (Dryer Repair)
by NaliKawi 2/2/2017 11:24:16 AM(UTC)
GE Hydrowave Top-Load... Thermistor Error... What Now? (Washer Repair)
by JoeyMac 8/12/2016 12:01:24 PM(UTC)
LG LSC27931ST Thermistor Part Number (Refrigerator & Freezer Repair)
by shackleford 11/12/2015 4:55:24 AM(UTC)
Duet E1 error after replacing thermistor (Dryer Repair)
by Steve8120 9/28/2014 6:48:28 PM(UTC)
Thermistor location(s) Refig and Freezer (Refrigerator & Freezer Repair)
by vincentjlawrence 9/15/2014 1:51:35 PM(UTC)
