| » Dryer Heats, but Takes a Long Time to Dry Clothes |
Model Number: LEW0050PQ1 Brand: Whirlpool Age: 1 - 5 years
This is s Whirlpool mini-duet.
It is taking multiple cycles to dry clothes and the drum seems to be running slower than normal (I think). I took off the exhaust tube and ran the unit, but, while the air was hot and humid, not much air seems to be coming out. There is no unusual odor coming from the unit (electrical, belt or otherwise). - Thanks |
Sounds like you have an obstruction in your air duct. Look down in the lint trap area and in the blower fan you will probably find a bunch of lint and a smaller artical of clothing (like a sock, underwear, etc.)
Post your results. nat |
Thanks, Nat. I checked the lint trap & ductwork and found it to be very clean (no globs of lint or clothing).
I then pulled off the back cover to the dryer and found the blower motor was very hot. Seeing there was an access cover to the blower motor, I pulled it off and fastened the rear cover again, then fired-up the unit. The blower motor was not turning at all. I was able to spin it (it spun freely), so I know the problem isn't a frozen bearing. What else would cause the blower motor to be hot but not spin? |
Try to pull the fan blade itself off the shaft. If you can get it off, inspect the back of the fan blade and the shaft it sets on. If the blade comes off easliy that might be your problem. A lot of times it actually has to be cut off.
Post your results. Nat |
Before I tore into the motor/fan blade assembly, I tried something...I turned the shaft with my fingers (it turns very freely) and it worked! BUT, the only way I can get the motor to turn is to start it my hand...It does work everytime IF I turn it by hand.
I know I'm narrowing it down (I got it to work just fine when I turn the shaft), but I still don't know what's causing the blower motor not to start when it should. Thoughts? |
| Display Modes | |
| Dryer takes a long time to dry | PaulLandru | Dryer Repair | 0 | 01-19-2008 03:53 PM |
| Dryer takes to long to dry | Julito | Dryer Repair | 1 | 12-05-2007 01:10 PM |
| Electric oven takes a long time to heat | kuroda01 | Oven Repair (including Ranges and Cooktops) | 0 | 11-04-2007 08:24 AM |
| oven takes long time to cook | Wmurky | Oven Repair (including Ranges and Cooktops) | 2 | 07-29-2007 01:01 PM |
| Dryer Takes Very Long to Dry Clothes | jdavis | Dryer Repair | 2 | 07-25-2007 05:00 PM |
