Discuss
Dryer Heats, but Takes a Long Time to Dry Clothes
 in
Dryer Repair
This is s Whirlpool mini-duet. It is taking multiple cycles to dry clothes and the drum seems to be
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer Heats, but Takes a Long Time to Dry Clothes
  #1 (permalink)
Old 08-23-2008, 10:24 AM
95breckut 95breckut is offline
Junior Member
95breckut is on a distinguished road
Default Dryer Heats, but Takes a Long Time to Dry Clothes
Model Number: LEW0050PQ1   Brand: Whirlpool   Age: 1 - 5 years
It is taking multiple cycles to dry clothes and the drum seems to be running slower than normal (I think).
I took off the exhaust tube and ran the unit, but, while the air was hot and humid, not much air seems to be coming out.
There is no unusual odor coming from the unit (electrical, belt or otherwise).
- Thanks
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-23-2008, 12:41 PM
libertyappl libertyappl is online now
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
Sounds like you have an obstruction in your air duct. Look down in the lint trap area and in the blower fan you will probably find a bunch of lint and a smaller artical of clothing (like a sock, underwear, etc.)
Post your results.
nat
  #3 (permalink)
Old 08-23-2008, 01:35 PM
Junior Member
Default
Thanks, Nat. I checked the lint trap & ductwork and found it to be very clean (no globs of lint or clothing).
I then pulled off the back cover to the dryer and found the blower motor was very hot. Seeing there was an access cover to the blower motor, I pulled it off and fastened the rear cover again, then fired-up the unit.
The blower motor was not turning at all. I was able to spin it (it spun freely), so I know the problem isn't a frozen bearing.
What else would cause the blower motor to be hot but not spin?
  #4 (permalink)
Old 08-23-2008, 02:19 PM
Senior Expert
APP Volunteer
Default
Try to pull the fan blade itself off the shaft. If you can get it off, inspect the back of the fan blade and the shaft it sets on. If the blade comes off easliy that might be your problem. A lot of times it actually has to be cut off.
Post your results.
Nat
  #5 (permalink)
Old 08-24-2008, 03:31 PM
Junior Member
Default
Before I tore into the motor/fan blade assembly, I tried something...I turned the shaft with my fingers (it turns very freely) and it worked! BUT, the only way I can get the motor to turn is to start it my hand...It does work everytime IF I turn it by hand.
I know I'm narrowing it down (I got it to work just fine when I turn the shaft), but I still don't know what's causing the blower motor not to start when it should.
Thoughts?
  #6 (permalink)
Old 08-24-2008, 08:23 PM
Senior Expert
APP Volunteer
Default
Do a continuity check on the capacitor or just purchase a new one. If it will start after you turn the shaft that probably the capacitor part number AP3777445
Nat
  #7 (permalink)
Old 08-28-2008, 09:28 PM
Junior Member
Default
Capacitor ordered and installed....problem solved. Thanks, Nat!!
  #8 (permalink)
Old 08-28-2008, 09:30 PM
Senior Expert
APP Volunteer
Default
You're welcome, glad I could help a little. Only way I use what knowledge I have ;o
Nat
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer takes a long time to dry PaulLandru Dryer Repair 0 01-19-2008 03:53 PM
Dryer takes to long to dry Julito Dryer Repair 1 12-05-2007 01:10 PM
Electric oven takes a long time to heat kuroda01 Oven Repair (including Ranges and Cooktops) 0 11-04-2007 08:24 AM
oven takes long time to cook Wmurky Oven Repair (including Ranges and Cooktops) 2 07-29-2007 01:01 PM
Dryer Takes Very Long to Dry Clothes jdavis Dryer Repair 2 07-25-2007 05:00 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
