| » No HEAT |
Thanks,
For starters lets start with the basics, go to your breaker box and turn the dryer breaker off wait a few seconds then turn it back on. Try the dryer see if it heats. If not then we'll move on to the next step. Get your ohm meter. Nat |
If you have an ohm meter.... remove the rear panel and look at where the wires make connections. Remove one set of connections at a time and test for continuity on each thermostat, if one has continuity then replace wires and move to the next. If all the thermostats have continuity then unplug the element and test it.
Post your results. Nat |
| Display Modes | |
| Roper (Gas) Dryer heats up then heat goes off (still running, no heat) | jtdesignsca | Dryer Repair | 3 | 01-17-2013 12:06 PM |
| Wall oven will not heat/re-heat properly | dottavio | Oven Repair (including Ranges and Cooktops) | 0 | 01-07-2010 09:47 AM |
| Dryer will not heat. It tumbles and cycles but it will not emit any heat. | agentsmith0505 | Dryer Repair | 0 | 10-14-2009 09:44 AM |
| Normal Heat Empty, Heat Shuts Off Full | BigDaddyG | Dryer Repair | 4 | 08-06-2009 03:17 PM |
| No Heat While Turning, Heat When Stopped thou | msg2008 | Dryer Repair | 1 | 08-07-2008 05:08 AM |
