3 Pages<123>
libertyappl
#11 Posted : Friday, August 22, 2008 8:11:44 AM(UTC)
libertyappl
I would suggest getting an ohm meter, even a cheap digital one or calling a tech
Nat
katiehussett
#12 Posted : Monday, August 25, 2008 2:30:35 PM(UTC)
katiehussett
Hello, I have never been on one of these before. I cant afford a guy to come do this so I bought my parts, there here, I put them on less the wires reconnected. I dont want to short out parts, will there actually be wires that are not reconnected? I have two wires left and no where to put them? HELP:eek:
libertyappl
#13 Posted : Monday, August 25, 2008 2:35:49 PM(UTC)
libertyappl
There should not be anywires left. post your model number please
katiehussett
#14 Posted : Monday, August 25, 2008 2:42:07 PM(UTC)
katiehussett
model number tedx640pq0
libertyappl
#15 Posted : Monday, August 25, 2008 2:48:08 PM(UTC)
libertyappl
which parts did you change out?
katiehussett
#16 Posted : Monday, August 25, 2008 2:51:20 PM(UTC)
katiehussett
I changed the heating element, and thermal cut off ? when I installed those parts it had a note on the instructions that if there was a 3/16 terminal connected then I had to do some cutting and crimping on the jumper wire.. Thats where it got tricky for me:mad:
katiehussett
#17 Posted : Monday, August 25, 2008 2:53:24 PM(UTC)
katiehussett
I could even take a picture, I just need to get this thing going again...ugggg
libertyappl
#18 Posted : Monday, August 25, 2008 2:54:51 PM(UTC)
libertyappl
ok, and post the part number of the thermal cutoff. There are different ones
katiehussett
#19 Posted : Monday, August 25, 2008 3:13:45 PM(UTC)
katiehussett
thermal cutoff kit 279816
here are a picture of new and the darker one with no wires is the older unit I took out :)
katiehussett attached the following image(s):
katiehussett
#20 Posted : Monday, August 25, 2008 3:21:35 PM(UTC)
katiehussett
I can tell you that the skinner orange one is not connected and it goes to where the timer control is. also there is a wire coming up from the bottom of the dryer (drum area) that is not connected anymore..
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag 1/5/2024 1:41:07 PM(UTC)
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam 11/2/2023 10:52:15 AM(UTC)
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 10/19/2023 4:56:37 PM(UTC)
No heat when assembled (Dryer Repair)
by Guest 8/16/2023 3:44:03 AM(UTC)
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
by Guest 7/13/2023 12:27:07 PM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
No heat, (Dryer Repair)
by tseibring 1/8/2023 7:57:44 AM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 7/5/2022 6:35:29 PM(UTC)
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 6/28/2022 11:03:33 AM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 2/6/2022 2:57:49 PM(UTC)
LG Gas Dryer No Heat - Control Panel? (Dryer Repair)
Belarus TomDBBills 1/29/2022 4:03:42 PM(UTC)
3 Pages<123>
