Discuss
kenmore 110 series won't stop
 in
Dryer Repair
i have kenmore dryer with the more dry-less dry feature thats quit working the dryer drys fine but won'
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » kenmore 110 series won't stop
  #1 (permalink)
Old 08-20-2008, 05:03 PM
chzbykr chzbykr is offline
Junior Member
chzbykr is on a distinguished road
Default kenmore 110 series won't stop
Model Number: 68378   Brand: Kenmore   Age: More than 10 years
i have kenmore dryer with the more dry-less dry feature thats quit working the dryer drys fine but won't stop when clothes are dry. any help be appreciated
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-20-2008, 06:46 PM
iamigor5@yahoo.com iamigor5@yahoo.com is offline
Senior Expert
APP Volunteer
iamigor5@yahoo.com is on a distinguished road
Default
need complete model number probably needs a thermistor does it turn off on timed dry???
  #3 (permalink)
Old 08-21-2008, 07:25 AM
Junior Member
Default kenmore 110 series won't stop reply
hi thnx for the reply. the model # inside the door is 86873800 (off to the side has just 68738). serial # is mx5130576. and no it doen't stop in timed dry either.
  #4 (permalink)
Old 08-28-2008, 10:27 AM
bronconaut bronconaut is offline
Junior Member
bronconaut is on a distinguished road
Default I have the same issue - Any thoughts?
I have the same issue with a Kenmore 110 dryer - it dries fine, but won't shut itself off with either timed dry or autosense dry. The timer knob does not move once set.
Thanks!
  #5 (permalink)
Old 10-01-2008, 07:06 PM
kmv kmv is offline
Junior Member
kmv is on a distinguished road
Default
I also have the same issue, dryer does not shut off. Any suggestions??
  #6 (permalink)
Old 10-01-2008, 07:11 PM
kmv kmv is offline
Junior Member
Default Kenmore dryer will not shut off
Model # 86872100 What part do I need?
  #7 (permalink)
Old 10-01-2008, 07:20 PM
Senior Expert
APP Volunteer
Default
i would probably guess it was the buzzer that is wired to the timer, long story short it drives the timer and the time will count down until last 5 mins and hangs. part #ap3094100
  #8 (permalink)
Old 10-02-2008, 07:29 AM
Junior Member
Default Bad Timer
In my case it was the timer. I replaced it and all is well. An easy way to check - BE VERY CAREFUL - is to watch the back of the timer as the dryer runs. On mine, there is a clear inspection cover. The timer motor was not turning at all. With the new timer you can see the timer motor rotating very clearly.
HTH.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Washer 80 Series steamguy456 Washer Repair 0 06-23-2008 02:18 PM
kenmore series 80 will not spin tlgeirna Washer Repair 1 06-04-2008 03:51 AM
Kenmore 80 series won't spin kenmorecrazy Washer Repair 0 03-15-2008 06:59 PM
Kenmore 90 series agitator helpme Washer Repair 1 03-02-2008 07:29 PM
800 series kenmore with no sensors? hardhat Dryer Repair 0 12-14-2007 08:06 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
