| » moisture sensor will not shut off dryer |
hope this does not complicate matters but since he can not use the moisture feature, he used the timer. He set it for 50 minutes and the clothes dryed nicely but the timer never moved. do you think that it may be two unrelated problems?
Give me your address and I will mail it to you in a regular envelope. If it works send me something to the return address if you feel like it. I am not in this to make any money but I just happen to have one of these parts and the least you can do is see if that really fixs the problem. Email me: sublimemasterjw@rocketmail.com
__________________
http://appliancejunk.com/forums/inde...referredby=858 http://sites.google.com/site/sublime...ncerepair/Home Last edited by SublimeMasterJW : 08-27-2008 at 12:13 PM. |
I would say it may not be the moisture sensing board but it may be timer motor itself. Power is not given to motor unless the moisture sensing board send that power in the auto cycle but the timer should move in the timed dry mode. You may want to check the timer motor for continuity.
Unfortunately you cannot buy just the timer motor anymore from regular outlets like the good old days. But you can have your timer sent off and rebuilt cheaper than getting a new one.
Go here: MTS - Main and see if you can get that puppy.
__________________
http://appliancejunk.com/forums/inde...referredby=858 http://sites.google.com/site/sublime...ncerepair/Home Last edited by SublimeMasterJW : 09-10-2008 at 08:14 PM. |
| Display Modes | |
| Where is moisture sensor? | brian44 | Dishwasher Repair | 1 | 12-13-2007 05:59 PM |
| Sensor on Neptune gas dryer | charliew | Dryer Repair | 1 | 09-30-2007 11:59 PM |
| Dryer finishes cycle but clothers damp - Test moisture sensor ? | rkpatt | Dryer Repair | 5 | 09-17-2007 10:08 AM |
| Moisture Sensor wire | dwiley824 | Dryer Repair | 1 | 09-09-2007 09:21 PM |
| moisture sensors | autoxracer | Dryer Repair | 3 | 09-04-2007 09:04 PM |
