Discuss
dryer heats but drum dont get warm
 in
Dryer Repair
I replaced my belt in my kenmore dryer and the door switch,The heating element glows but the drum isnt
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer heats but drum dont get warm
  #1 (permalink)
Old 09-16-2007, 07:28 AM
weity weity is offline
Junior Member
weity is on a distinguished road
Angry dryer heats but drum dont get warm
Model Number: 86574710   Brand: Kenmore   Age: More than 10 years
I replaced my belt in my kenmore dryer and the door switch,The heating element glows but the drum isnt even warm!!What sensor could that be?? everything else works ,It said to use a ohm meter set at R 1 and test the sensor.My ohm meter dont have that setting hmmm...
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-16-2007, 07:30 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
This is a strange one. Need more info. Does the blower blow air out the back, is your ducting clogged up?
__________________
  #3 (permalink)
Old 09-16-2007, 07:51 AM
Junior Member
Default
yes it blows out the back!!!! no clogs as far as i can see
  #4 (permalink)
Old 09-16-2007, 07:52 AM
Junior Member
Default
i never touched anything else...i put aload of towels in it and well. they did not dry at all!!!!!
  #5 (permalink)
Old 09-16-2007, 07:57 AM
Junior Member
Default
Set your multimeter to the R X 1 setting. Take each of your meter's probes and touch one to each terminal. You are testing for continuity, and you should receive a reading of either zero or infinity. At room temperature, testing the thermostat should produce a reading of zero. But if a thermostat is tested when it is heated to its limit, a reading of infinity should be produced. We strongly recommend that you test your thermostat at room temperature.
rx10 is what im supose to use as a setting guess ill have to go get a dif ohm meter!!!!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer only heats once abe Dryer Repair 1 09-16-2007 12:00 AM
I need a part # and I dont know what it is. lol tracyd73 Washer Repair 5 09-05-2007 09:43 AM
microwave dont heat Ruben Lucero Microwave Repair 0 09-01-2007 03:24 PM
Dryer drum won't turn tlathan Dryer Repair 1 08-15-2007 05:12 PM
Maytag Dryer: Drum Not Turning miatahowie Dryer Repair 2 07-26-2007 08:18 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
