Dryer heats during diagnostic only. Diagnostic shows no errors. I have made the tests for "won't heat" I have found main coil reading @ 1305 instead of 1220 +/-50. The vent is clean clear to outside. If the heat works during diagnostics is the main coil really bad ?
