Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   drum wont turn (http://forum.appliancepartspros.com/dryer-repair/11053-drum-wont-turn.html)
Reenie50 08-19-2008 09:03 AM
drum wont turn
drum wont turn dryer hums when you push the knob but wont go around
:confused:
Reenie50 08-19-2008 09:08 AM
hello
:confused:
abadfish66 08-19-2008 09:18 AM
Can you spin the drum by hand fairly easy?
Reenie50 08-19-2008 09:25 AM
I can turn it but it seems to rub
abadfish66 08-19-2008 09:28 AM
Can you identify where the rub noise is coming from? Does it sound like the drum rubbing on the front, sides, rear. If up front, run your hand along the inside between the drum and dryer front for anything like a penny caught between the drum and dryer lip.
Reenie50 08-19-2008 09:30 AM
I lifted the top and the belt is in tact and on the front side of drum is the rubbing
abadfish66 08-19-2008 09:33 AM
ok, with the top off, start the dryer and see if the drum tries to turn.
Reenie50 08-19-2008 09:34 AM
I did that and no it wont turn
abadfish66 08-19-2008 09:38 AM
You may have a broken roller...Model PYE2300AYW
Or something is stuck in the blower wheel located at the lower left. To check further, you will need to remove the front of the dryer and inspect.
Reenie50 08-19-2008 09:43 AM
how do I know if is broken
