WW47
#1 Posted : Thursday, July 29, 2010 1:07:03 PM(UTC)
WW47
Heating element was burned out so I replaced with new element as well as new thermostat. Dryer turns on but element does not heat up. What else should be checked?
ThatGuy
#2 Posted : Thursday, July 29, 2010 6:12:10 PM(UTC)
ThatGuy
Groups: Expert
United States
Does your house have fuses or circuit breakers that power the dryer? Do you have 240 volts to the dryer?
You see a dryer can run on 120 volts, but not heat. So you might be missing half your voltage.
Or you could have a bad timer or burnt off wire or an open cycling thermostat.
dryer won't heat up (Dryer Repair)
by dnell 8/26/2014 7:21:16 PM(UTC)
LG gas dryer won't heat up (Dryer Repair)
by Farmer85 10/2/2013 9:21:16 AM(UTC)
GE electric dryer won't heat up (Dryer Repair)
by jrogers 7/4/2013 11:55:26 AM(UTC)
by Teresay 6/11/2013 6:40:08 PM(UTC)
Dryer won't heat up (Dryer Repair)
by ford4wd08 6/11/2013 9:42:58 AM(UTC)
frigidaire dryer won't heat up (Dryer Repair)
by wilde1537 5/6/2013 10:27:04 AM(UTC)
Whirlpool Duet Gas Dryer Won't Heat Up (Dryer Repair)
by evanr99 2/1/2013 6:16:21 PM(UTC)
Maytag Electric Dryer won't heat up (Dryer Repair)
by rajpat25 7/7/2012 12:56:23 PM(UTC)
by d burns 5/17/2012 12:18:14 PM(UTC)
Bosch Dryer won't heat up (Dryer Repair)
by tericribb 3/18/2012 10:05:30 AM(UTC)
Whirlpool Thin Twin Washer Dryer Combo, Dryer won't heat up (Dryer Repair)
by NVChickey 2/25/2012 10:50:02 PM(UTC)
Dryer won't heat up to dry clothes (Dryer Repair)
by tdeai 7/21/2011 3:55:49 PM(UTC)
by krisr 2/8/2011 2:52:24 PM(UTC)
Heating Element on Roper Dryer won't heat up (Dryer Repair)
by c grass 11/23/2010 5:26:01 AM(UTC)
GE Electric Dryer won't heat up (Dryer Repair)
by lizt 12/27/2009 12:07:30 PM(UTC)
