| » Whirlpool Gas Dryer Runs, Start Heating then gas heat goes off - stays off... |
Model Number: SGD5800HQ0 Brand: Whirlpool Age: 5 - 10 years
Gas dryer starts/runs ok AT START... but heating stops after about 5-10min (with tumbler/blower still going). To be clear, sequence is:
- dryer starts/runs AS NORMAL for a minute or so... - then i can see glow/igniter start... - gas flame lights & runs as normal for ~5-10min... > but then stops & does not relight (although I've seen glow/igniter heat up) - dryer continued tumbling on with cool air. :-( Other info: * if allowed to cool down for say 5min, will restart above sequence * if a quick 1min stop/restart tried, there is no gas re-lighting (although glow/igniter goes on for a few seconds) * I suspect the sensor (on heater section), yes/no? It measure less than 1ohm accross whether hot OR cold. * i have not tested/measured other thermostats... Thx. DRS Can see the glow/igniter Ads By Google Related Models |
Found that:
-Sensor continuity good, at ~0 ohms (still); -Main thermostat, has 4 leads; > with ~0 ohms between two of them and > approx. 7k ohms between the 2nd set of leads. -Backup thermostat at 0 ohms Whether hot or cold, the resistances above do not seem to change. Let me know that you think. Thx. DRS |
DRS,
According to your description, most likely the problem with your dryer is a bad gas valve coils. - The part number for the kit of coils is AP3094251 Here are the break down diagrams for the Whirlpool dryer Model SGDS800HQ0 Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Gene & ibertyappl;
Are you guys talking about the same part; coils / regulator? According to your description, most likely the problem with your dryer is a bad gas valve coils. ( AP3094251 ). Diagrams for the Whirlpool dryer Model SGDS800HQ0. Thx. DRS |
| Display Modes | |
| Dryer Runs Only if Start Button Held Down, But No Heat | mholiver | Dryer Repair | 0 | 02-15-2010 01:36 PM |
| Whirlpool Dryer runs with no heat | Dslaughter | Dryer Repair | 2 | 11-20-2009 12:17 PM |
| whirlpool Dryer-heat stays on; now no start | jttgb24 | Dryer Repair | 9 | 02-04-2008 06:23 PM |
| Dryer Runs Only if Start Button Held Down, But No Heat | Stephen D | Dryer Repair | 2 | 01-21-2008 07:28 PM |
| Whirlpool gas dryer runs but no heat | c1gia | Dryer Repair | 0 | 08-14-2007 08:26 PM |
