The iginiter glows red but the gas does not fire up. The dryer continues to spin and the iginiter comes on repeatedly every few minutes. Pls help.
Originally Posted by: lizpet35 The iginiter glows red but the gas does not fire up. The dryer continues to spin and the iginiter comes on repeatedly every few minutes. Pls help. Your description leads me to believe , you have a failed gas valve solenoid(coil) on you gas valve. Are you sure the gas has not been turned off to the the dryer? Please varify your description: igniter glows red and goes out in a few seconds but no gas is released. If this is all correct, I suggest you start at replacing the coil kit on the gas valve. Pleas see attached part number and picture. Good luck, Part number: AP3094251
i ordered EXACT part today.......$23,,,,not bad with shipping.
mine did samething....i saw glow...so that parts good. i ordered coils............lets c.;)
Originally Posted by: aircargoo i ordered EXACT part today.......$23,,,,not bad with shipping.
mine did samething....i saw glow...so that parts good. i ordered coils............lets c.;) You're welcome, happy laundering.
I had the same problem. I checked my coils for continuity and got nothing. I ordered the coils and I'm not getting continuity on the new ones right out of the box. Shouldn't I be getting continuity on these new ones?
Originally Posted by: cb3 I had the same problem. I checked my coils for continuity and got nothing. I ordered the coils and I'm not getting continuity on the new ones right out of the box. Shouldn't I be getting continuity on these new ones?
Thanks Yes you should be able to read resistance across the coils. Is your meter set to the correct ohms resistance range ? The 2 terminal coil should read apprximately 1000 ohms. the 3 terminal coil should read approximately 500 ohms across the 2 outside terminals, an 1300 ohms across the middle terminal and the pin to left side (term. #1)of the dual coil solenoid terminals.
It was an audible meter. Touching the leads together produced a loud beep but touching the coil terminals produced nothing. I should return these? Thanks
Originally Posted by: cb3 It was an audible meter. Touching the leads together produced a loud beep but touching the coil terminals produced nothing. I should return these? Thanks Do you know the RX scale of the meter ? I prefer an anolog meter or adjustable digital meter, not one that beeps only or an auto ranger meter. A bad part out of the box is a possibility. You may want to return them and try again, but if you get the same resistance, try another meter on the correct settings.
