Discuss
Stops early, now only runs on 1 cycle
 in
Dryer Repair
Model: GEQ9858JQ0 The first symptom was the dryer would stop mid-cycle & the start button would have to be
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Stops early, now only runs on 1 cycle
  #1 (permalink)
Old 08-12-2008, 08:16 PM
Help_ Repairs Help_ Repairs is offline
Junior Member
Help_ Repairs is on a distinguished road
Default Stops early, now only runs on 1 cycle
Model Number: GEQ9858JQ0   Brand: Whirlpool   Age: 5 - 10 years
Model: GEQ9858JQ0
The first symptom was the dryer would stop mid-cycle & the start button would have to be pushed to continue the cycle. This was an intermittent problem. Now the dryer will only operate on one setting, while not completing the cycle. It will only operate the length of time between the closest 2 lines. If the cloths are not dry, the “operating window” has to be restarted, as the start button will no longer continue the remaining time of the cycle. What could some of the causes be?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-14-2008, 05:41 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
If you have no meter, I would pull the cover off the timer and check for burnt contacts.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer runs then stops before cycle is over cobra9646 Dryer Repair 4 10-21-2008 08:35 AM
Dryer runs 5 min. and stops chuckman Dryer Repair 2 08-14-2008 07:14 PM
DW runs for 15 seconds and stops verbeek1 Dishwasher Repair 1 06-23-2008 09:56 PM
Gas Dryer Runs but Heat Stops Working terrib Dryer Repair 1 12-26-2007 04:37 PM
dryer runs then stops mike_T Dryer Repair 0 09-04-2007 06:41 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
