Im at a complete loss with my dryer. It runs but does not get heat. I have redid the wire from the breaker to the outlet. Replaced the outlet and breaker. I have tested every component in the dryer. Everything has continuity . bought a new dryer hooked it up and it doesn’t heat either. Tested everything on it and its all fine. I replaced the wire with 10/3. Am I missing something? Any help would greatly be appreciated.
Make sure you wired it correctly, the black and red wires go to the outside connector terminals, and the white wire goes in the middle. If a three wire plug, the frame of the dryer must go to the middle terminal.
