| » Lp Gas Dryer |
Brand: Admiral Age: 5 - 10 years
My dryer takes a long time to dry my clothes, I hear something click on
and off as it is running and it doesn't get very hot, is it possible it is a thermostat or could it be that one of the high or low regulators is bad |
I would run it without the attached ducting and see if it now works ok. If so, you need to clean your ducting. If a long run, you will need a "Lint Eater brush".
They probably have it at this parts site, just call.
__________________
With the dryer running go outside and make sure you have good airflow out the vent. Also take the vent off from the wall, and take a temp reading of the exhaust air with the dryer running. Should be around 180 degrees and when the heat stops, you should lose about 1 degree per second.
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!! Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up. |
| Display Modes | |
