Discuss
No Power on dryer, power to outlet and cord
 in
Dryer Repair
I have an electric dryer, just over 3 years old. Recently we had a lot of electrical issues due to
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » No Power on dryer, power to outlet and cord
  #1 (permalink)
Old 07-21-2010, 10:08 PM
Junior Member
dorn27 is on a distinguished road
Default No Power on dryer, power to outlet and cord
Model Number: AEQ6000es2   Brand: Frigidaire   Age: 1 - 5 years
Recently we had a lot of electrical issues due to storms, and we also cut power to our house while replacing a light switch. It was after the storms and replacment that we started a load of wash. When moving it to the dryer, we noticed the dryer has NO power. At first I was under the impression that it was the breaker box, needing a switch replaced or reset... but then I bought an AC voltage tester. One that senses outlets and through wires without direct contact.
The sensor indicates there is power to outlet, and power up the dryers power cord. However, I have no lights, no nothing on my dryer... except some mildew stink forming in my washer from wet clothes sitting over 36 hours!
I've taken apart (after unpluging since outlet is live) the back where the power cord is attached. Nothing is loose. I checked all three connections and the grounding wire.
I'm not sure what could be the problem. I'm not even sure where to go next. Considering I paid $600 for the things several years ago, I don't want to pay a $600 repair bill.
Any advice would be cherished. I'm not sure what else to check. Everything just says "check connections", and check that your house hasn't tripped/blown fuse. Both have already been ruled out.
Also in April this year I had a problem where it would not stop spinning unless unplugged, even out of cycle or turned off. It was not running heat while this was happening, or I probably would have had a fire. I ran diagnostics on it then, and it came up as a jammed button (with I never did find). I cleaned around all buttons and inside the door, reset with electronic code (needs power) and all was fine until now.
Related Models
Frigidaire AEQ6000ES2 Frigidaire/dryer
Frigidaire AEQ6400HE0 DRYER
Frigidaire AEQ6400HS0 DRYER
Frigidaire AEQ6500CFG0 Frigidaire/dryer
Frigidaire AEQ6500CFS0 DRYER
Frigidaire AEQ6700CFE0 DRYER
Frigidaire AEQ6700CFS0 DRYER
Frigidaire AEQ6700FE0 DRYER
Frigidaire AEQ6700FS0 DRYER
Frigidaire AEQ7000CEG0 Frigidaire/dryer
Frigidaire AEQ7000CES0 Frigidaire/dryer
Frigidaire AEQ7000CES1 Frigidaire/dryer
Frigidaire AEQ7000CFE0 Frigidaire/dryer
Frigidaire AEQ7000EE0 Frigidaire/dryer
Frigidaire AEQ7000EG0 Frigidaire/dryer
Frigidaire AEQ7000EP0 Frigidaire/dryer
Frigidaire AEQ7000ES0 Frigidaire/dryer
Frigidaire AEQ7000ES1 Frigidaire/dryer
Frigidaire AEQ8000CFE0 DRYER
Frigidaire AEQ8000CFG0 DRYER
Frigidaire AEQ8000CFS0 DRYER
Frigidaire AEQ8000FE0 DRYER
Frigidaire AEQ8000FG0 DRYER
Frigidaire AEQ8000FS0 DRYER
Frigidaire AEQ8700FE0 DRYER
Frigidaire AEQ8700FG0 DRYER
Frigidaire AEQ8700FS0 DRYER
Frigidaire AEQB6000ES0 Frigidaire/dryer
Frigidaire AEQB6000ES1 Frigidaire/dryer
Frigidaire AEQB6000ES2 Frigidaire/dryer
Frigidaire AEQB6400FS0 DRYER
Frigidaire AEQB7000EG0 Frigidaire/dryer
Frigidaire AEQB7000EP0 Frigidaire/dryer
Frigidaire AEQB7000ES0 Frigidaire/dryer
Frigidaire AEQB7000ES1 Frigidaire/dryer
General Electric AER05LHW1 Room air conditioner
General Electric AER05LLG1 ROOM AIR CONDITIONER
General Electric AER05LLS1 ROOM AIR CONDITIONER
General Electric AER05LNH1 ROOM AIR CONDITIONER
General Electric AER05LNL1 ROOM AIR CONDITIONER
General Electric AER05LNQ1 ROOM AIR CONDITIONER
General Electric AER05LPL1 ROOM AIR CONDITIONER
General Electric AER05LPQ1 ROOM AIR CONDITIONER
General Electric AER05LPW1 ROOM AIR CONDITIONER
Admiral AER1110AAH RANGE- F/S STD ELE
Admiral AER1110BAH RANGE- F/S STD ELE
Admiral AER1140AGH RANGE- F/S STD ELE
Admiral AER1150AAH RANGE- F/S STD ELE
Admiral AER1350AAH RANGE- F/S STD ELE
Admiral AER1350AAL RANGE- F/S STD ELE
Admiral AER1350AAT RANGE- F/S STD ELE
Admiral AER1350AMH RANGE- S/C F/S ELE
Admiral AER1350BAH RANGE- S/C F/S ELE
Admiral AER1350BAT RANGE- S/C F/S ELE
Admiral AER1360AGW RANGE- S/C F/S ELE
Admiral AER1360BGW RANGE- S/C F/S ELE
Admiral AER1450AAH RANGE- F/S STD ELE
Admiral AER1450BAH RANGE- F/S STD ELE
Admiral AER2350AMH RANGE- F/S STD ELE
Maytag AER3311WAW0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Amana AER4111AAW RANGE- F/S STD ELE
Amana AER4311AAW RANGE- F/S STD ELE
Amana AER5511AAB RANGE- S/C F/S ELE
Amana AER5511AAQ RANGE- S/C F/S ELE
Amana AER5511AAW RANGE- S/C F/S ELE
Amana AER5511ACB RANGE- S/C F/S ELE
Amana AER5511ACW RANGE- S/C F/S ELE
Amana AER5511BAB RANGE- S/C F/S ELE
Amana AER5511BAQ RANGE- S/C F/S ELE
Amana AER5511BAW RANGE- S/C F/S ELE
Amana AER5515QAQ RANGE- S/C F/S ELE
Amana AER5515QAW RANGE- S/C F/S ELE
Amana AER5515QCW RANGE- S/C F/S ELE
Amana AER5515RCW RANGE- S/C F/S ELE
Maytag AER5522VAS0 30" ELECTRIC FREESTANDING SELF CLEAN RANGE
Maytag AER5522VAW0 30" ELECTRIC FREESTANDING SELF CLEAN RANGE
Maytag AER5522VCS0 30" ELECTRIC FREESTANDING SELF CLEAN RANGE
Maytag AER5522VCW0 30" ELECTRIC FREESTANDING SELF CLEAN RANGE
Amana AER5710BAH RANGE- S/C F/S ELE
Amana AER5712AAQ RANGE- S/C F/S ELE
Amana AER5712AAS RANGE- S/C F/S ELE
Amana AER5712AAW RANGE- S/C F/S ELE
Amana AER5712AAZ RANGE- S/C F/S ELE
Amana AER5712ACW RANGE- S/C F/S ELE
Amana AER5712ACZ RANGE- S/C F/S ELE
Amana AER5712BAB RANGE- S/C F/S ELE
Amana AER5712BAW RANGE- S/C F/S ELE
Amana AER5712BAZ RANGE- S/C F/S ELE
Amana AER5715QAQ RANGE- S/C F/S ELE
Amana AER5715QAS RANGE- S/C F/S ELE
Amana AER5715QAW RANGE- S/C F/S ELE
Amana AER5715QCB RANGE- S/C F/S ELE
Amana AER5715QCS RANGE- S/C F/S ELE
Amana AER5715QCW RANGE- S/C F/S ELE
Amana AER5715RCB RANGE- S/C F/S ELE
Amana AER5715RCS RANGE- S/C F/S ELE
Amana AER5715RCW RANGE- S/C F/S ELE
Amana AER5722BAB RANGE- S/C F/S ELE
Amana AER5722BAQ RANGE- S/C F/S ELE
Amana AER5722BAS RANGE- S/C F/S ELE
Amana AER5722BAW RANGE- S/C F/S ELE
Amana AER5722CAS RANGE- S/C F/S ELE
Amana AER5725QAF RANGE- S/C F/S ELE
Amana AER5725QAN RANGE- S/C F/S ELE
Amana AER5725QAQ RANGE- S/C F/S ELE
Amana AER5725QAW RANGE- S/C F/S ELE
Amana AER5735QAB RANGE- S/C F/S ELE
Amana AER5735QAF RANGE- S/C F/S ELE
Amana AER5735QAN RANGE- S/C F/S ELE
Amana AER5735QAQ RANGE- S/C F/S ELE
Amana AER5735QAS RANGE- S/C F/S ELE
Amana AER5735QAW RANGE- S/C F/S ELE
Amana AER5815RCB RANGE- S/C F/S ELE
Amana AER5815RCS RANGE- S/C F/S ELE
Amana AER5815RCW RANGE- S/C F/S ELE
Maytag AER5821VAS0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Maytag AER5821VAW0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Maytag AER5822VAB0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Maytag AER5822VAD0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Maytag AER5822VAS0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
  #2 (permalink)
Old 07-26-2010, 05:15 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
First get a multi meter and check that you are getting 120v to each side of the connection block.
If so, disconnect the dryer and use the wiring diagram to start tracing the wiring from the connection block to the timer.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Neptune Dryer - no power at all after power cord poli Dryer Repair 0 07-09-2010 07:46 AM
dryer power cord jpkay Dryer Repair 1 09-11-2009 10:04 AM
how to hook up 3-wire power cord to terminal on maytag dryer starcraft1 Dryer Repair 1 08-14-2009 07:33 AM
how do I change the power cord on Whirlpool dryer? mpurvance Dryer Repair 1 08-02-2009 07:32 AM
my dryer power cord melted away momthree Dryer Repair 1 04-21-2009 08:10 PM
