Discuss
Fried Dryer
 in
Dryer Repair
I was hooking up a wire power cable to a washer that previously had a 3 wire power cable. In
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Fried Dryer
  #1 (permalink)
Old 08-11-2008, 10:09 AM
maxthelen maxthelen is offline
Junior Member
maxthelen is on a distinguished road
Default Fried Dryer
Brand: Kenmore   Age: 1 - 5 years
I was hooking up a wire power cable to a washer that previously had a 3 wire power cable. In the process I accidentally put a hot(black) wire on the neutral terminal which sent a pulse of electricity surging down the dryer and burnt the lint hose off the wall. After consulting google I wired it correctly (Red, Black hot on outside terminals, white neutral on middle terminal and green ground on frame screw.) Now I know the dryer is getting electricity because it is wired correctly and the light inside is coming on, but the control panel (which is all digital) shows no signs of life. Is there a fuse I can replace or do I just need to buy a new dryer?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-11-2008, 09:58 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the control board is gone bad. For more accurate advise we need the complete model number of the dryer.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 08-12-2008, 07:13 AM
Junior Member
Default I believe the model
number is: 110.64082201
  #4 (permalink)
Old 08-12-2008, 04:19 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The part number for the control board is AP3841286 but there is a chance that some more parts are damaged too. You can find it only after the control board replaced.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
fried by power failure? tonyfix Oven Repair (including Ranges and Cooktops) 0 10-06-2007 03:23 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
