Discuss
dryer won't start
 in
Dryer Repair
when trying start dryer I get a huming noise but will not start.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer won't start
  #1 (permalink)
Old 08-11-2008, 07:09 AM
jofthree jofthree is offline
Junior Member
jofthree is on a distinguished road
Default dryer won't start
Model Number: DBL333EB3WW   Brand: GE   Age: 1 - 5 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-11-2008, 08:49 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem is a bad motor. You can run a simple test to verify it.
Open the door, push and hold the door switch, push the start button and turn the drum manually. If it'll start then the motor has to be replaced.
- The part number for the motor is AP2043571
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer will not start at all Andrewisgod Dryer Repair 0 07-11-2008 06:23 PM
Dryer won't start SINDONE Dryer Repair 0 06-30-2008 11:42 AM
Dryer doesn't start doug7as Dryer Repair 1 01-20-2008 12:48 PM
Dryer won't start shangki Dryer Repair 1 12-17-2007 09:16 PM
Dryer will not start bob38 Dryer Repair 2 09-19-2007 08:59 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
