Discuss
Dryer Stops for 20-30 min
 in
Dryer Repair
I have an Admiral dryer that is about 1 yr old -last April I moved into a brand new home
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer Stops for 20-30 min
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 09-13-2007, 05:51 PM
cowboy2296 cowboy2296 is offline
Junior Member
cowboy2296 is on a distinguished road
Exclamation Dryer Stops for 20-30 min
Brand: Admiral   Age: Less than 1 year
I have an Admiral dryer that is about 1 yr old -last April I moved into a brand new home and now the dryer will dry one maybe two loads and shut down for 20-30 minutes-after that this cycle begins again. one or two loads (and not full capacity loads) then off
I wonder if anyone can tell me the problem since it only started when the dryer was moved to the new home approx 700' total moving distance
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-14-2007, 02:52 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Sounds like your motor is overheating and stopping on internal overload switch.
Check motor bearings and look around for a burnt/loose wire to motor.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
stops on heating delay between cycles scoot Dishwasher Repair 1 09-13-2007 02:14 AM
dryer runs then stops mike_T Dryer Repair 0 09-04-2007 05:41 AM
Freezer fan stops ccfed3 Refrigerator & Freezer Repair 1 08-28-2007 04:14 PM
Dryer stops before loads are dry,esp on High setting azhorn Dryer Repair 2 08-02-2007 03:05 PM
Dryer stops running after letting off the Start button Andy Dryer Repair 10 08-01-2007 09:56 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
