| » Drum Seal Replacement |
Model Number: MDE2500AYW Brand: Maytag Age: 5 - 10 years
My Maytag dryer was making screeching sounds. After removing the front assembly I found the felt drum seal was torn at the top where the 2 ends come together. I also found one of the tabs used to hold the seal in place had broken off and may have been causing the drum noise. I reassembled the dryer, forcing the seal in place, and it is now running quietly.
But I may still need to replace the seal - so I have two questions: First, can I simply replace the felt seal using the remaining tabs or do I need to replace the front bulk head as well? If I replace the seal, do I bend the tabs slightly to get the seal under them and then bend them back? I don't want to fatigue the metal tabs. Thanks, Ken Ads By Google Related Models |
| Display Modes | |
| Whirlpool Dryer rear felt drum seal replacement | wagnes | Dryer Repair | 0 | 07-13-2010 07:29 AM |
| Rear drum seal | psmccoy | Dryer Repair | 1 | 04-20-2010 03:56 AM |
| Duet Dryer Drum Seal Replacement | nmfnet | Dryer Repair | 4 | 10-08-2009 04:46 AM |
| rear drum seal replacement | mfd611 | Dryer Repair | 1 | 07-07-2009 12:46 PM |
| Replacing Drum Seal | gpaciotti@cytimmune.com | Dryer Repair | 3 | 01-15-2008 05:28 PM |
