| » Dryer does not run when let go of start buttom |
Open the control panel and located the tech sheet. On the tech sheet in the wiring diagram locate the start switch and follow the lines test all components in that line for continuity you can trace it that way. Without seeing the tech sheet myself I think when you hold the start button down it bypasses the door switch(going from memory). I will try to locate the tech sheet on line and look for certain.
| Display Modes | |
| Dryer will not start at all | Andrewisgod | Dryer Repair | 0 | 07-11-2008 06:23 PM |
| Dryer won't start | scrump | Dryer Repair | 1 | 05-23-2008 05:29 PM |
| dryer will still not start | allyvania | Dryer Repair | 1 | 02-12-2008 08:10 PM |
| dryer won't start | Beagle | Dryer Repair | 0 | 02-12-2008 06:00 PM |
| Dryer will not start - sometimes | stripe5 | Dryer Repair | 1 | 11-26-2007 07:45 PM |
