Discuss
Whirlpool dryer does nothing
 in
Dryer Repair
Our dryer quit. It does nothing at all. No heat, drum doesn't turn, nothing. I tested the door switch and
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool dryer does nothing
  #1 (permalink)
Old 08-06-2008, 07:44 PM
Junior Member
Jon P is on a distinguished road
Default Whirlpool dryer does nothing
Model Number: LER7646DQ1   Brand: Whirlpool   Age: 5 - 10 years
Our dryer quit. It does nothing at all. No heat, drum doesn't turn, nothing. I tested the door switch and it is good. I also checked the breaker in my fuse box. There is no noise what so ever, not even a click. Timer settings or temp settings don't matter either. I was thinking maybe a start switch-relay?
Ads By Google
Related Models
Whirlpool LER7646DQ1
Whirlpool LER7646DW0
Whirlpool LER7646DW1
Whirlpool LER7646DZ0
Whirlpool LER7646DZ1
Whirlpool LER7646EQ0
Whirlpool LER7646EQ1
Whirlpool LER7646EQ2
Whirlpool LER7646EZ0
Whirlpool LER7646EZ1
Whirlpool LER7646EZ2
Whirlpool LER7646JQ0
Whirlpool LER7646JT0
Whirlpool LER7648KQ0
Whirlpool LER7648KQ1
Whirlpool LER7648KQ2
Whirlpool LER7648KQ3 29"electric Dryer
Whirlpool LER7648KT0
Whirlpool LER7648KT1
Whirlpool LER7648KT2
Whirlpool LER7648KT3 29"electric Dryer
Whirlpool LER7648PQ0 29" Electric Dryer
Whirlpool LER7648PQ1 29" Electric Dryer
Whirlpool LER7648PT0 29" Electric Dryer
Whirlpool LER7648PT1 29" Electric Dryer
Whirlpool LER7848DQ0
Whirlpool LER7848DQ1
Whirlpool LER7848DZ0
Whirlpool LER7848DZ1
Whirlpool LER7858AN0
Whirlpool LER7858AN1
Whirlpool LER7858AN2
Whirlpool LER7858AW0
Whirlpool LER7858AW1
Whirlpool LER7858AW2
Whirlpool LER8620PG0 29"electric Dryer
Whirlpool LER8620PG1 29"electric Dryer
Whirlpool LER8620PW0 29"electric Dryer
Whirlpool LER8620PW1 29"electric Dryer
Whirlpool LER8648LG0
Whirlpool LER8648LG1 29"electric Dryer
Whirlpool LER8648LQ0
Whirlpool LER8648LW0
Whirlpool LER8648LW1 29"electric Dryer
Whirlpool LER8648PG0 29"electric Dryer
Whirlpool LER8648PG1 29"electric Dryer
Whirlpool LER8648PQ0 29" Electric Dryer
Whirlpool LER8648PQ1 29"electric Dryer
Whirlpool LER8648PW0 29"electric Dryer
Whirlpool LER8648PW1 29"electric Dryer
Whirlpool LER8857EQ0
Whirlpool LER8857EQ1
Whirlpool LER8857EQ2
Whirlpool LER8857EZ0
Whirlpool LER8857EZ1
Whirlpool LER8857EZ2
Whirlpool LER8858DQ0
Whirlpool LER8858DQ1
Whirlpool LER8858DZ0
Whirlpool LER8858DZ1
Whirlpool LER8858EQ0
Whirlpool LER8858EQ1
Whirlpool LER8858EQ2
Whirlpool LER8858EZ0
Whirlpool LER8858EZ1
Whirlpool LER8858EZ2
Amana LES10AW Washer - Top Loading
Amana LES19AW Dryer - Gas
Amana LES33AW Dryer - Gas
Amana LES34AW Washer - Top Loading
Frigidaire LES389FEA Frigidaire/electric Range
Frigidaire LESR26EFE0 Frigidaire/refrigerator
Amana LET-480 Range - S/c S/i Ddraft Gas
Amana LET-480A Range - S/c S/i Ddraft Gas
Amana LET-480B Range - S/c S/i Ddraft Gas
Amana LET-480C Range - S/c S/i Ddraft Gas
Whirlpool LET5434AN0
Whirlpool LET5434AQ0
Whirlpool LET5434AW0
Whirlpool LET5436AN0
Whirlpool LET5436AW0
Whirlpool LET5624BN0
Whirlpool LET5624BN1
Whirlpool LET5624BN2
Whirlpool LET5624BQ0
Whirlpool LET5624BQ1
Whirlpool LET5624BQ2
Whirlpool LET5624BW0
Whirlpool LET5624BW1
Whirlpool LET5624BW2
Whirlpool LET5624DQ0
Whirlpool LET5624DQ1
Whirlpool LET6634AN0
Whirlpool LET6634AN1
Whirlpool LET6634AN2
Whirlpool LET6634AQ0
Whirlpool LET6634AQ1
Whirlpool LET6634AQ2
Whirlpool LET6634AW0
Whirlpool LET6634AW1
Whirlpool LET6634AW2
Whirlpool LET6634DQ0
Whirlpool LET6634DQ1
Whirlpool LET6634DZ0
Whirlpool LET6634DZ1
Whirlpool LET6638AN0
Whirlpool LET6638AN1
Whirlpool LET6638AN2
Whirlpool LET6638AQ2
Whirlpool LET6638AW0
Whirlpool LET6638AW1
Whirlpool LET6638AW2
Whirlpool LET6638DQ0
Whirlpool LET6638DQ1
Whirlpool LET6638DZ0
Whirlpool LET6638DZ1
Whirlpool LET7646AN0
Whirlpool LET7646AQ0
Whirlpool LET7646AQ1
Whirlpool LET7646AQ2
  #2 (permalink)
Old 08-07-2008, 02:41 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Verify 230 volts to the dryer, then check the thermal fuse, a narrow white plastic item on the blower housing.
__________________
  #3 (permalink)
Old 08-09-2008, 01:41 PM
Junior Member
Default
richappy,
I have 230v to the dryer. So I tested that thermal fuse and found it is open. I ordered a new one and hope that is all that is wrong with it. Any reason why they fail? Old age? Thanks for your help. Much cheaper than replacing the dryer.
  #4 (permalink)
Old 08-10-2008, 04:03 AM
Senior Expert
APP Volunteer
Default
Sometimes they just wear out. You should check your ducting for a partial restriction that can overheat the dryer.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Burned Dryer Plug - Whirlpool Electric Dryer EastCobbSnob Dryer Repair 4 11-17-2009 06:45 PM
whirlpool Dryer Tammy43 Dryer Repair 1 11-04-2009 04:33 PM
Whirlpool Gas Dryer SandraB Dryer Repair 3 07-24-2009 01:49 PM
Whirlpool Dryer Has no Heat in Dryer jsanabia Dryer Repair 1 06-08-2009 04:36 PM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 10:47 AM
