Discuss
universal dryer motor application?
 in
Dryer Repair
Dryer motor applicability. The AP part number, AP 3094245, contains the description that it fits dryers made by Whirlpool and
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » universal dryer motor application?
  #1 (permalink)
Old 07-14-2010, 10:18 AM
Junior Member
gman2cnslt is on a distinguished road
Default universal dryer motor application?
Model Number: 110.66912691   Brand: Kenmore   Age: More than 10 years
The AP part number, AP 3094245, contains the description that it fits dryers made by Whirlpool and fits ALL dryers whose model number starts with the prefix 110 made 1996 and before. The difference in this unit and the one specified by the part numbers specific to the model I have, (a 110 prefix model Kenmore) are the lengths of the shafts.
The direct replacement has a 1 5/8 inch long blower shaft and 1 1/4 inch long drive shaft.
The universal unit has 1 3/4 inch long shafts for both.
Can this unit be used without modification?
What problems with the shaft length cause on the drive side with alignment and operation of the belt, etc?
Thank you.
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 07-14-2010, 10:58 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
You have a Dot model dryer that requires a short shaft motor. Your idler pulley placement is fixed and the long shaft motor pulley will not mate with this. You will not be able to allign the belt around both pulleys.
__________________
  #3 (permalink)
Old 07-14-2010, 11:40 AM
Junior Member
Default
Thank you for the input and clarification.
My only concern with this, still, is in the description of the item that I referenced and the phrase that includes ". . .all" and references specifically the "110 prefixes."
Perhaps someone could review the description and, if deemed appropriate, amend it not to include "all" units.
  #4 (permalink)
Old 07-14-2010, 01:22 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Can you explain how did you find the motor with the part number AP3094245?
The OEM part number for the motor designed to fit the Kenmore dryer with the model number 110.66912691 is 279787. This Whirlpool part number is AP3094233 Appliance Parts Pros part number. This part number does not cross over to the part number you referred in your post.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #5 (permalink)
Old 07-14-2010, 01:38 PM
Junior Member
Default Private Conversation?
Hi Gene,
I am not sure, as I reply to this, if it is "posted" for all to see or not.
I would prefer a more private way to discuss this.
If you can reply via my e-mail address and include a phone number or a contact for IM, I will get in touch.
  #6 (permalink)
Old 07-14-2010, 03:14 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I would contact people whom you purchased this motor from to return the wrong motor and order the correct part.
If you purchased this motor from Appliance Parts Pros, then there are not going to be any problems because of their very friendly return policy. Just talk to their team.
__________________
  #7 (permalink)
Old 07-14-2010, 04:02 PM
Junior Member
Default
Hi Gene,
I hadn't purchased the motor yet as I was looking for clarification as to applicability before I ordered it.
I was working under the assumption that a motor unit was used in multiple dryers and if, as this one did, one said it was applicable to many machines, it might work in mine if the cross-reference specs aligned.
I found this one by going to APP site, looking under Dryer Parts, using "part description" and inputting, "dryer motor" and reading the various unit descriptions. The one I had questions about was $50 + cheaper and stated, as said before, that it applied to Whirlpool dryers before '96 and specifically states "...kenmore with model numbers whose prefix is 110..."
The questions I had, as written, surrounded the different shaft lengths for drive side and blower side and I needed them clarified before I would have ordered that unit.
I have been told that it won't be applicable and I appreciate that.
I still think someone at APP should look at the wording of the description of that particular unit for the reasons stated and described throughout the post(s).
Thank you for your attention to this and the help you provided.
Gary
  #8 (permalink)
Old 07-14-2010, 05:16 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome Gary.
I forwarded your post to the APP team and the description for this motor has been fixed.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
3-1 Universal Starter Relay tkwock Refrigerator & Freezer Repair 11 10-14-2010 02:33 AM
New Universal Motor Coupling (part no AP3963893 ) (direct drive) won't fit properly felixq78 Washer Repair 1 05-03-2010 07:27 AM
GE Universal Dryer Motor Kit showphone Dryer Repair 5 06-14-2009 04:57 PM
mars universal timer bigtex73 Heating, Ventilation, and Air Conditioning (HVAC) 1 05-31-2009 07:15 PM
Universal Microwave Waleed Microwave Repair 1 02-04-2008 02:29 PM
