| » Dryer Will Not Run |
Model Number: DDE5100RALWH Brand: GE Age: More than 10 years
When I go to set the timer on the dryer, there is a humming noise and nothing happens. Usually I can set the timer and then use the starter switch. Will replacing the timer solve the problem or is there more to what could be causing it not to run?
Get someone to help you and have them press the start switch while you depress the door switch and manually turn the drum. If it starts up you have the classic symptoms of a bad motor.
__________________
| Display Modes | |
| Dryer won't heat and I don't know how to take the back cover of the dryer off to chec | dcwike | Dryer Repair | 2 | 11-25-2009 07:40 AM |
| Burned Dryer Plug - Whirlpool Electric Dryer | EastCobbSnob | Dryer Repair | 4 | 11-17-2009 06:45 PM |
| Dryer will not heat and now smell gas when I open the dryer door | oheguy | Dryer Repair | 1 | 03-10-2009 12:59 PM |
| Gas Dryer tumbles but won't heat. Timer does not move when dryer is started. | NEAL AMES | Dryer Repair | 1 | 01-02-2009 06:40 PM |
| coin op dryer timer starts but dryer doesn't turn on | Mike Craw | Dryer Repair | 4 | 01-10-2008 07:26 PM |
