Discuss
Dryer will not dry when attached to vent.
 in
Dryer Repair
My dryer will not dry. When I pull everything from the dryer (vent) it dries just fine. I plug it
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer will not dry when attached to vent.
  #1 (permalink)
Old 08-04-2008, 01:25 PM
uk2us88 uk2us88 is offline
Junior Member
uk2us88 is on a distinguished road
Default Dryer will not dry when attached to vent.
Brand: Whirlpool   Age: 1 - 5 years
My dryer will not dry. When I pull everything from the dryer (vent) it dries just fine. I plug it up to the vent and will not dry until about the 4th run. Our home is new construction and from what I can tell the vent is clear. It runs straight up with on small angle. The dryer worked wonders until we moved. It has got to be something with the vent. Is there anything else I can check other than the lint and vent?
Thanks in advance!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-04-2008, 01:32 PM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
If there is no air moving outside the house it wont dry, you need to look closely at the outside vent, if there is a flapper, make sure it is free to open, if that looks fine, then it is blocked inside somewhere.
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
  #3 (permalink)
Old 08-04-2008, 01:36 PM
Junior Member
Default
Thanks for the quick reply. It vents out of the roof. I will climb up there this evening after it cools and see if I can feel anything. Should the force be strong?
  #4 (permalink)
Old 08-04-2008, 01:39 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
You should feel a good flow of air coming out. Here in Arizona alot of builders run the vent out the roof, and they use a screen to keep birds out, and this screen cloggs up with lint rather quickly, if this is the case, remove the screen and throw it away.
__________________
  #5 (permalink)
Old 08-04-2008, 01:41 PM
Junior Member
Default
Great thanks. Yeah in NC its in the 90's already and to hot to run up there for me. I'll check it out and post back here later this evening or first thing tomorrow. thanks for the info.
  #6 (permalink)
Old 08-04-2008, 01:46 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
90, thats winter weather here in AZ, 114 yesterday
__________________
  #7 (permalink)
Old 08-05-2008, 06:47 AM
Junior Member
Default
Thats dry heat though right? Our Humidity is a beast.....
Anyway, I went on the roof last night and pulled of the screen like yu said. Man that thing was clogged. I am not sure of the purpose of it as there also is some sort of flapper that closes once the dryer is off. It looks like I fixed the problem!
Thanks for the heads up!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer Vent jburd964@yahoo.com Dryer Repair 0 08-01-2008 08:12 PM
dryer vent condensation alwcharles Dryer Repair 3 06-20-2008 12:27 PM
Convert Vent - Whirlpool Duet Gas Dryer hhammond Dryer Repair 2 04-17-2008 05:56 AM
dryer not heating, vent full of water dyardbird Dryer Repair 1 02-20-2008 02:52 PM
help with dryer vent cralya Dryer Repair 0 10-03-2007 12:42 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
