Discuss
Dryer squeaking
 in
Dryer Repair
When dryer comes on it has loud squeaking noise, then after awhile it quits. I sprayed idler arm with LPS
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer squeaking
  #1 (permalink)
Old 08-04-2008, 01:04 PM
mamadoog mamadoog is offline
Junior Member
mamadoog is on a distinguished road
Default Dryer squeaking
Model Number: SDE4606AYW   Brand: Maytag   Age: 1 - 5 years
When dryer comes on it has loud squeaking noise, then after awhile it quits. I sprayed idler arm with LPS 1, it quite for a while but came back. Help please.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-05-2008, 12:50 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Remove the front panel and the front bulkhead assembly (#5 on the break down diagram). Check both glides (front supports for the drum, # 11 on the break down diagram).
Remove the drum and check the rear drum support rollers (#16 on the break down diagram).
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer stopped after several months of squeaking Amie Dryer Repair 10 08-02-2008 07:49 AM
Admiral Dryer Squeaking for 1 - 3 minutes theresa.addison Dryer Repair 0 06-15-2008 05:44 AM
washer squeaking auxesis Washer Repair 2 03-30-2008 08:55 PM
ge dryer is making loud squeaking noise georgepannier@sbcglobal.n Dryer Repair 3 12-28-2007 11:23 PM
dryer works but it is squeaking remi Dryer Repair 0 10-23-2007 06:36 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
