Discuss
installing a new 4 prong cord to 3 prong dryer
 in
Dryer Repair
I have a new townhome with a 4 prong outlet. My neptune dryer has a 3 prong. I purchased the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » installing a new 4 prong cord to 3 prong dryer
  #1 (permalink)
Old 08-04-2008, 08:53 AM
nmcfay1226 nmcfay1226 is offline
Junior Member
nmcfay1226 is on a distinguished road
Default installing a new 4 prong cord to 3 prong dryer
Model Number: MDE6800Ayw   Brand: Maytag   Age: 1 - 5 years
I have a new townhome with a 4 prong outlet. My neptune dryer has a 3 prong. I purchased the right cord, but now need to hhok it up. the dryer terminal has a black terminal, a white terminal and a third terminal with two blue wires on it. My 4 prong cord has a blk, wht , red and green wires. Where do they go??I have already blown one circiut board and have ordered a new one from you guys, please help.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-04-2008, 09:00 AM
SublimeMasterJW SublimeMasterJW is offline
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default
White goes into the middle red goes on one end and black goes on the other end. Green is ground and goes to a green screw.4 wire setup.jpg
  #3 (permalink)
Old 08-04-2008, 09:20 AM
Junior Member
Default
what if there is no visible green ground screw on the unit? can I leave it off?
  #4 (permalink)
Old 08-04-2008, 09:39 AM
abbie abbie is offline
Senior Expert
APP Volunteer
abbie is on a distinguished road
Default
NO ..The dryer should be grounded.If there no holes in metal close to the block[hook up] then drill one in the metal close to where you hooked up the other wires in the block.[dryers back panel]Then use a self- threading screw and tighten the screw to the green wire.If there is paint under that screw remove the paint for a good ground.
__________________
  #5 (permalink)
Old 08-05-2008, 08:33 AM
Senior Expert
APP Volunteer
Default
That green wire goes anywhere on the chassis(body) of the dryer. You really need this to be connected to the dryer. You could use one of those screws that hold the terminal block or just get a screw and make a hole.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
convert four prong plug to a three prong hooked25259 Dryer Repair 1 07-17-2008 09:11 PM
Kenmore Elite 110.62952100 crossed 3 & 4 prong cord connections ediconex99 Dryer Repair 6 05-14-2008 06:08 PM
Jenn-Air cartridge retro-fit 3 prong/4 prong vfxmark Oven Repair (including Ranges and Cooktops) 0 01-02-2008 10:32 AM
Rewiring 4 prong to a three prong nicolem Dryer Repair 1 12-13-2007 10:01 PM
dryer cord wiring jschutter Dryer Repair 0 11-21-2007 06:20 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
