Discuss
Dryer won't heat AND making noise
 in
Dryer Repair
I had the T-stat and thermal fuse replaced 4 mo ago, and has worked great since. He said it
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer won't heat AND making noise
  #1 (permalink)
Old 08-02-2008, 01:24 PM
jdd425 jdd425 is offline
Junior Member
jdd425 is on a distinguished road
Default Dryer won't heat AND making noise
Model Number: LGR7646EQ3   Brand: Whirlpool   Age: 5 - 10 years
I had the T-stat and thermal fuse replaced 4 mo ago, and has worked great since. He said it burned out because of my venting config. I live in a 2 story, and they ran the vent from the base board on bottom floor up to the space between the 2 floors and out to the side of the house. However, I have been checking the air flow and it seems to be fine.
Now it doesn't heat and it is making a noise like something is hitting the drum. It runs for a few minutes with no noise then the noise starts. Don't know how to describe noise any better Sorry
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-04-2008, 03:57 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
You may have a partial duct restriction. I use a flow meter to check. You can buy a duct cleaning brush online called a "lint Eater", Just crunch that into Google to get it. You now probably have a blown thermal fuse located at the top of the heater cover. If a low frequency noise, you probably have a busted drum roller.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Electric dryer making screeching noise Windsurfer Dryer Repair 1 07-10-2008 03:11 PM
My dryer is making a loud noise GinaB Dryer Repair 2 04-09-2008 03:11 PM
ge dryer is making loud squeaking noise georgepannier@sbcglobal.n Dryer Repair 3 12-28-2007 11:23 PM
Dryer Making a Humming Noise Bigboss88 Dryer Repair 2 12-07-2007 01:08 PM
Dryer Making Noise eperdue Dryer Repair 0 11-24-2007 11:22 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
