Discuss
Dryer will not turn on has power other test done
 in
Dryer Repair
Hello everyone... I am pretty new to this site, and have looked over it a good deal. There seems to
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer will not turn on has power other test done
  #1 (permalink)
Old 07-06-2010, 01:24 PM
Junior Member
KCgallimore is on a distinguished road
Default Dryer will not turn on has power other test done
Model Number: LER4634JQ1   Brand: Whirlpool   Age: 5 - 10 years
Hello everyone... I am pretty new to this site, and have looked over it a good deal. There seems to be a lot of knowledgable people who help and visit here. So I am turning to you guys hopefully to help me look in the right direction.
Problem: Dryer will not turn on at all.
I can not hear any hum noise when pushing or holding in the start button, and it just seems dead.
Doesnt seem to be jammed. I turned the drum. It was very tight though. Dont remember it always being that tight to turn.
I have checked brakers.
Checked it with an ohm meter, and that turned up nothing.
I have turned it with the clip inside the door pushed in, and the start button pushed in. It didnt start up then either.
I do not see anything in the back to give away any kind of issues either. No burning sighted or anything like that.
If any of you can help that would be great.
Thank you
Cass
Ads By Google
Related Models
Whirlpool LER4634JQ1
Whirlpool LER4634JQ2 29" Electric Dryer
Whirlpool LER4634JT0
Whirlpool LER4634JT1
Whirlpool LER4634JT2 29" Electric Dryer
Whirlpool LER4634JZ0
Whirlpool LER4634PQ0 29" Electric Dryer
Whirlpool LER4634PQ1 29" Electric Dryer
Whirlpool LER4634PT0 29" Electric Dryer
Whirlpool LER4634PT1 29" Electric Dryer
Whirlpool LER5434AN0
Whirlpool LER5434AW0
Whirlpool LER5600HQ0
Whirlpool LER5600HZ0
Whirlpool LER5600JQ0
Whirlpool LER5600JT0
Whirlpool LER5620KQ0
Whirlpool LER5620KQ1
Whirlpool LER5620KQ2 29"electric Dryer
Whirlpool LER5624BN0
Whirlpool LER5624BN1
Whirlpool LER5624BN2
Whirlpool LER5624BW0
Whirlpool LER5624BW1
Whirlpool LER5624BW2
Whirlpool LER5624DQ0
Whirlpool LER5624DQ1
Whirlpool LER5624DW1
Whirlpool LER5624DZ0
Whirlpool LER5624DZ1
Whirlpool LER5634AN0
Whirlpool LER5634AQ0
Whirlpool LER5634AQ1
Whirlpool LER5634AQ2
Whirlpool LER5634AW0
Whirlpool LER5634DQ1
Whirlpool LER5634EQ0
Whirlpool LER5634EZ0
Whirlpool LER5634LG0
Whirlpool LER5634LQ0 29" Electric Dryer
Whirlpool LER5634LT0
Whirlpool LER5634LW0
Whirlpool LER5635LQ0 29"electric Dryer
Whirlpool LER5635LQ1 29"electric Dryer
Whirlpool LER5636DW0
Whirlpool LER5636DW1
Whirlpool LER5636EQ0
Whirlpool LER5636EQ1
Whirlpool LER5636EQ2
Whirlpool LER5636EQ3
Whirlpool LER5636EZ0
Whirlpool LER5636EZ1
Whirlpool LER5636EZ2
Whirlpool LER5636EZ3
Whirlpool LER5636JQ0
Whirlpool LER5636JT0
Whirlpool LER5636KQ0
Whirlpool LER5636KQ1
Whirlpool LER5636KT0
Whirlpool LER5636KT1
Whirlpool LER5636LG0
Whirlpool LER5636LQ0
Whirlpool LER5636LQ1 29"electric Dryer
Whirlpool LER5636LT0
Whirlpool LER5636LT1 29"electric Dryer
Whirlpool LER5636LW0
Whirlpool LER5636PQ0 29"electric Dryer
Whirlpool LER5636PQ1 29"electric Dryer
Whirlpool LER5636PT0 29"electric Dryer
Whirlpool LER5636PT1 29"electric Dryer
Whirlpool LER5638AN0
Whirlpool LER5638AN1
Whirlpool LER5638AN2
Whirlpool LER5638AN3
Whirlpool LER5638AW0
Whirlpool LER5638AW1
Whirlpool LER5638AW2
Whirlpool LER5638AW3
Whirlpool LER5644AN0
Whirlpool LER5644AN1
Whirlpool LER5644AN2
Whirlpool LER5644AW0
Whirlpool LER5644AW1
Whirlpool LER5644AW2
Whirlpool LER5644EQ0
Whirlpool LER5644EQ1
Whirlpool LER5644EQ2
Whirlpool LER5644EZ0
Whirlpool LER5644EZ1
Whirlpool LER5644EZ2
Whirlpool LER5644JQ0
Whirlpool LER5644JQ1
Whirlpool LER5644JQ2
Whirlpool LER5644JQ3 29"electric Dryer
Whirlpool LER5644JT0
Whirlpool LER5644JT1
Whirlpool LER5644JT2
Whirlpool LER5644JT3 29"electric Dryer
Whirlpool LER5644PQ0 29"electric Dryer
Whirlpool LER5644PQ1 29"electric Dryer
Whirlpool LER5700KQ0
Whirlpool LER5700KQ1
Whirlpool LER5700KT0
Whirlpool LER5700KT1
Whirlpool LER5848EQ0
Whirlpool LER5848EQ1
Whirlpool LER5848EQ2
Whirlpool LER5848EQ3
Whirlpool LER5848EQ4
Whirlpool LER5848EQ5
Whirlpool LER6611LQ0
Whirlpool LER6611LQ1 29"electric Dryer
Whirlpool LER6611PQ0 29" Electric Dryer
Whirlpool LER6620PQ0 29"electric Dryer
Whirlpool LER6620PQ1 29"electric Dryer
Whirlpool LER6620PT0 29"electric Dryer
Whirlpool LER6620PT1 29"electric Dryer
Whirlpool LER6621PQ0 29" Electric Dryer
Whirlpool LER6634BN0
Whirlpool LER6634BN1
  #2 (permalink)
Old 07-06-2010, 06:33 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Cass,
Remove the rear panel and check the thermal fuse (#19 on the diagram) for continuity. If there is no continuity, replace it.
- The thermal fuse Part number: AP3132867
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LER4634JQ1 | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 07-10-2010, 06:20 AM
Junior Member
Default
Thanks for the reply Gene. We tested that fuse today, and that does not seem to be the issue. We will keep trying.
Cass
  #4 (permalink)
Old 07-10-2010, 01:48 PM
Expert
APP Volunteer
Brevard Appliance Repair is on a distinguished road
Default
I would guess the thermel fuse as well but since you tested it and its good then check your door switch...good luck
  #5 (permalink)
Old 07-10-2010, 07:55 PM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here is your wiring diagram in case you do not have it
http://www.servicematters.com/docs/w...%208528187.pdf
Also check the start switch.
First I would check the power
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Turntable does not turn and no power ravnsflock Microwave Repair 9 07-17-2011 07:43 PM
how to test if power is going to control panel robvinceint Dishwasher Repair 1 02-06-2010 01:50 AM
Power On Switch does not turn on display lights or operation richardrbailey Washer Repair 3 10-13-2009 06:43 PM
Washer will not turn on...no power jrs_concrete Washer Repair 2 06-22-2009 04:47 AM
Dryer does not turn has power to plug and unit wxperez Dryer Repair 2 05-24-2009 08:09 AM
