Discuss
Timer doesn't advance
 in
Dryer Repair
History: About 3 years ago dryer would not start when set in Intelli Dry Mode for "Normal" or "More Dry."
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Timer doesn't advance
  #1 (permalink)
Old 07-05-2010, 08:37 AM
Junior Member
sdrake is on a distinguished road
Default Timer doesn't advance
Brand: Maytag   Age: 1 - 5 years
History: About 3 years ago dryer would not start when set in Intelli Dry Mode for "Normal" or "More Dry." It otherwise worked OK in "Less Dry" and timed dry mode. The problem occurred at the same time lightening knocked out a garage door opener, a radio, a cordless phone etc. We continued using the dryer this way because most of the time the "Less Dry" setting dried the clothes sufficiently.
Recently the timer stopped advancing at all and the dryer would start as before with the missing settings but it would not shut off. The dryer had to be shut down manually.
I ordered a new timer from ApliancePartsPros and plugged it in. The new timer does not advance on any setting. With the new timer the dryer will now start in the "Normal" or "More Dry" settings but it still does not advance. Have I gotten a defective timer or is there something else in the dryer that could cause the timer to not advance even though the dryer is running? What other part can I swap and have a good chance of fixing this like new dryer.
This is Maytag model MDE7657BYW
Ads By Google
  #2 (permalink)
Old 07-07-2010, 02:54 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Wiring information replacement parts for MAYTAG MDE7657BYW Dryer - Ele | AppliancePartsPros.com
And a manual
http://www.servicematters.com/maytag...s/16023110.pdf
This may also help.
http://www.applianceaid.com/dryers.html
Could be the cycling thermostat or the dryness board.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Timer won't advance. irhoghead Dryer Repair 1 01-09-2010 07:52 PM
Timer Won't Advance Slovaks4ever Dryer Repair 2 08-08-2009 09:50 AM
Timer won't advance wwwpol Dryer Repair 3 01-30-2009 01:00 PM
Timer will not advance dzieour@ranchomurieta.org Dryer Repair 1 11-25-2008 11:48 AM
Timer does not advance Lloyd Kneller Washer Repair 1 09-26-2007 02:18 AM
