| » low drys like high |
Model Number: LE4440XWW0 Brand: Whirlpool Age: More than 10 years
Hi, my whirlpool shut off after 20mins( on high setting).of being ran. cooled down and ran for a couple of mins. shut down again . set the temp. setting to low and work find as if it was on high temp(normal dry time) . duck to outside clean. i see there is 3 thermostats 1.high limit 2.plain thermostat 3. dry cycling thermostat or the swicth for air,high and low.
which could it be. thanks for your time. |
Hi Robert,
I would recommend to replace the cycling and "flat" thermostats (#19 & #24 on the break down diagram). Also I would recommend to check the chute (#1 on the break down diagram) for build-up lint inside. Here are the break down diagrams for the Whirlpool dryer Model LE4440XWW0 Gene.
__________________
Professional appliance repair in Los Angeles, California. |
| Display Modes | |
| gas flame too high - no adjustment | willywilly | Oven Repair (including Ranges and Cooktops) | 0 | 01-23-2008 08:08 AM |
| Burner high | Gardener | Oven Repair (including Ranges and Cooktops) | 0 | 01-08-2008 11:52 AM |
| High temp. setting too hot | RPS | Dryer Repair | 2 | 12-22-2007 02:48 AM |
| oven flames too high | ssedillo | Oven Repair (including Ranges and Cooktops) | 5 | 12-18-2007 01:29 PM |
| High flame in oven | cstric1 | Oven Repair (including Ranges and Cooktops) | 1 | 12-06-2007 06:13 PM |
