Discuss
low drys like high
 in
Dryer Repair
Hi, my whirlpool shut off after 20mins( on high setting).of being ran. cooled down and ran for a couple
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » low drys like high
  #1 (permalink)
Old 07-31-2008, 12:04 AM
robert daly robert daly is offline
Junior Member
robert daly is on a distinguished road
Default low drys like high
Model Number: LE4440XWW0   Brand: Whirlpool   Age: More than 10 years
Hi, my whirlpool shut off after 20mins( on high setting).of being ran. cooled down and ran for a couple of mins. shut down again . set the temp. setting to low and work find as if it was on high temp(normal dry time) . duck to outside clean. i see there is 3 thermostats 1.high limit 2.plain thermostat 3. dry cycling thermostat or the swicth for air,high and low.
which could it be. thanks for your time.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-31-2008, 10:12 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Robert,
I would recommend to replace the cycling and "flat" thermostats (#19 & #24 on the break down diagram). Also I would recommend to check the chute (#1 on the break down diagram) for build-up lint inside.
Here are the break down diagrams for the Whirlpool dryer Model LE4440XWW0
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
gas flame too high - no adjustment willywilly Oven Repair (including Ranges and Cooktops) 0 01-23-2008 08:08 AM
Burner high Gardener Oven Repair (including Ranges and Cooktops) 0 01-08-2008 11:52 AM
High temp. setting too hot RPS Dryer Repair 2 12-22-2007 02:48 AM
oven flames too high ssedillo Oven Repair (including Ranges and Cooktops) 5 12-18-2007 01:29 PM
High flame in oven cstric1 Oven Repair (including Ranges and Cooktops) 1 12-06-2007 06:13 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
