Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   dryer wont turn on (http://forum.appliancepartspros.com/dryer-repair/104365-dryer-wont-turn.html)
ritadi 07-04-2010 10:30 AM
dryer wont turn on
Checked The Push To Start Switch,and Door Latch Harness,both Good.light Is On.belt Is Good,timer Good????
denman 07-07-2010 03:18 AM
Replacement parts for WHIRLPOOL MED5600TQ0 29" Electric Dryer | AppliancePartsPros.com
Here is a wiring diagram
http://www.servicematters.com/docs/w...%208576817.pdf
I am assuming that the light goes off when you push the door switch.
I have a bit of a problem here as the wiring diagram shows a thermal fusr in line with the motor but the parts does not show one.
If it has one it will be mounted on the blower assembly alonng with the cycling thermostat.
