| » Need help with whirlpool dryer |
Model Number: GEW9868KQ4 Brand: Whirlpool Age: 1 - 5 years
Dryer is only year and a half old and it wont start. Light inside is fine and that's all. Can't select program, no beeping...Nothing. I ordered new electronic board but that's not the problem. Please HELP!
The first thing I would do is check the door switch.
Even the light inside the dryer is fine, the switch has to be checked for continuity because it switches power between the inner light and the controls and this part of the switch can be bad. When the door is open there suppose to be continuity between the terminals where the white and brown wires are connected. When the door switch is depressed there suppose to be continuity between the terminals where the white and blue wires are connected. The wire harness plug for the switch has to be disconnected during the test. - The part number for the door switch is AP3132865 Gene.
__________________
Professional appliance repair in Los Angeles, California. |
__________________
If this dude is open then the dryer will not runfuse 2.jpgLocated on the rear of the dryer in the exhaust area, it monitors excessive heat levels due to blocked venting and lint buildup.fuse location.jpg
Thanks alot for all your help. I think the console is dead. I checked every part in the dryer following the tech sheets. Gene, Thanks for sending me this link! I am going to order a new one now and will post if it's fixed.
| Display Modes | |
| wHIRLPOOL dRYER NEEDS HELP | WAYNE JAROSH | Dryer Repair | 2 | 07-31-2008 09:51 PM |
| Whirlpool Dryer | DanaNicholson | Dryer Repair | 4 | 02-03-2008 04:44 PM |
| whirlpool dryer | a1lady | Dryer Repair | 3 | 01-29-2008 07:35 PM |
| Whirlpool gas dryer | Paul Solarz | Dryer Repair | 3 | 12-16-2007 03:25 PM |
| Estate Dryer by Whirlpool/Dryer running but no heat | tsm11238 | Dryer Repair | 1 | 11-06-2007 11:47 AM |
