Discuss
How to slow a dryer down
 in
Dryer Repair
Hi, I need to slow the rotation of the drum down on a dryer. The material I am drying gets
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » How to slow a dryer down
  #1 (permalink)
Old 07-02-2010, 05:47 PM
Junior Member
pcroyle is on a distinguished road
Smile How to slow a dryer down
Brand: Whirlpool   Age: Less than 1 year
I need to slow the rotation of the drum down on a dryer. The material I am drying gets beat up with so much tumbling. Any ideas how to decrease the amount of revolutions per minute?
I know it's like the opposite of fixing, but there is always at least one in the crowd that wants to go the other direction.
Pete
Ads By Google
  #2 (permalink)
Old 07-02-2010, 10:01 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Pete,
Technically it is impossible because it will affect the air flow through the dryer.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 07-04-2010, 09:42 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Yes, you can use a universal speed control on the motor, but you will have to use it on the motor circuit only. A speed control must be designed to operate a motor and not lights. Also, it must be able to handle 5 amps. This is well over the current limits of most speed controls availabe at Wall Mart, so you must order it from a supplier.
A better solution would be to remove the plastic baffle from the drum, this will reduce the stress on the material.
__________________
  #4 (permalink)
Old 07-07-2010, 03:21 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
If the drum has several baffles in it you may want to remove all but one.
Or you could try removing all of them.
Have never tried this so it may not work as it may not tumble the clothes at all or may wrap them into one big ball.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
noisey dryer slow to dry Don OBrian Dryer Repair 3 05-08-2011 10:14 AM
Dryer Slow To Dry CASKDB Dryer Repair 0 04-28-2010 10:00 PM
slow gas dryer mrgetmm1 Dryer Repair 2 03-09-2010 05:50 AM
Dryer is very slow is drying cass19 Washer Repair 1 01-05-2010 01:19 PM
Dryer Dries To Slow Javier Dryer Repair 2 08-21-2007 06:35 PM
