Discuss
Whirlpool Duet Sport Dryer wont start
 in
Dryer Repair
I have an electric Whirlpool Duet Sprt dryer that will not start . Control panel lights indicate it senses wet clothes
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Duet Sport Dryer wont start
  #1 (permalink)
Old 07-30-2008, 06:50 AM
Jstout Jstout is offline
Junior Member
Jstout is on a distinguished road
Unhappy Whirlpool Duet Sport Dryer wont start
Model Number: WED8300SWO   Brand: Whirlpool   Age: 1 - 5 years
I have an electric Whirlpool Duet Sprt dryer that will not start . Control panel lights indicate it senses wet clothes but will not start. Went into diagnstic mode and got an F-26 code (motor drive system failure). Door switch checks o.k. and jumpered the thermal fuse to eliminate it and still wont start. Any suggestions ??
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-30-2008, 09:26 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The control diagnosed motor drive system failure. Next step you should do is run the Test #2 on the page 5 as recommended in the Tech Sheets.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 07-31-2008, 08:19 AM
Junior Member
Default Whirlpool Duet
Thanks for the advice , but I'm not experienced enough to do the checks,so I had a sevice call and the machine control electronics board was diagnosed as bad. (about $160 for part and $80 for service call)
  #4 (permalink)
Old 08-20-2008, 08:35 AM
ridge111 ridge111 is offline
Junior Member
ridge111 is on a distinguished road
Default Bad solder joints
Mine also would not start and the lights on the control panel were acting funny. Also when you turn the dial it would go to a random selection. Sometimes shutting off the breaker for a few minutes and back on seemed to help but then that stopped making any difference. After reading these forums and finding a link to the service guide, I got the error code F-02 "Keypad/User Interface Failure". No surprise there.
Since many people seem to be having this problem and it doesn't start to happen until months after buying it (mine is about 18 months old), I suspected (hoped for) cold solder joints on the circuit boards. For those who don't know, a "cold" solder joint means that the soldering was not done properly. Soldering is welding, and if you don't get it hot enough to saturate into the metal then you end up with a joint that is more like glued together (surfaces touching) than an actual weld. Over time these joints will come loose or oxidation builds between the surfaces and you get an intermittent connection. It's not uncommon. The joints will usually have a dull grey color if they're bad, rather than smooth and shiny silver.
So I removed the control panel and looked at the circuit boards. There are 2 main boards where the buttons are mounted and a small one containing the rheostat for the dial. Immediately it looked to me like the joints might be cold. So I resoldered the joints on all three boards and it worked! Dryer works like new again and I saved a couple hundred dollars.
This is a manufacturing defect. If you're under warranty then you probably want to just make the call and hope that the service guy gets it right the first time. Mine was out of warranty so it was worth a try. Plus I know how to solder. If you don't then find someone who does or pay for the repair. It's not the most difficult soldering job but if you haven't done it before then it will be a real mess. Hope this helps.
  #5 (permalink)
Old 08-20-2008, 02:11 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
ridge111,
Thanks a lot! Very helpful information.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Duet Sport washer seems stuck in drain cycle luistorres Washer Repair 5 07-25-2008 06:16 AM
help my washer, a whirlpool duet sport flusteredhousewife Washer Repair 0 07-20-2008 02:19 PM
Whirpool Duet Sport Won't Pump Out Haynesnorm Washer Repair 1 07-11-2008 04:28 PM
error codes on whirlpool duet sport Thad Steele Washer Repair 1 11-02-2007 03:12 PM
Duet Sport F01 error Code vposton Washer Repair 2 09-15-2007 08:20 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
