Discuss
Amana Dryer
 in
Dryer Repair
Replaced thermal fuse 2 months ago. Same problem again. Received new part and installed. Won't run.....Metered all parts on heating
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Amana Dryer
  #1 (permalink)
Old 06-30-2010, 05:34 PM
Junior Member
johns problem is on a distinguished road
Default Amana Dryer
Model Number: le8317w2   Brand: Amana   Age: 5 - 10 years
Replaced thermal fuse 2 months ago. Same problem again. Received new part and installed. Won't run.....Metered all parts on heating element board..all o.k. Can't find any disconnected wires, breaker is good, all pluged in.....stumped
John Van
Ads By Google
Related Models
Amana LE8317W2 Dryer - Ele
Amana LE8317W2B Dryer - Ele
Amana LE8327W Dryer - Ele
Amana LE8367L2 Washer - Top Loading
Amana LE8367W2 Dryer - Ele
Amana LE8407L2 Dryer - Ele
Amana LE8407W Dryer - Ele
Amana LE8407W2 Dryer - Ele
Amana LE8457L2 Dryer - Ele
Amana LE8457W Dryer - Ele
Amana LE8457W2 Dryer - Ele
Amana LE8467L2 Dryer - Ele
Amana LE8467W2 Dryer - Ele
Amana LE8507W Dryer - Ele
Amana LE8517L2 Dryer - Ele
Amana LE8517W2 Dryer - Ele
Amana LE8517W2B Dryer - Ele
Amana LE8567L2 Dryer - Ele
Amana LE8567W2 Dryer - Ele
Whirlpool LE8600XWN0
Whirlpool LE8600XWW0
Amana LE8607L2 Dryer - Ele
Amana LE8607W Dryer - Ele
Amana LE8607W2 Dryer - Ele
Whirlpool LE8650XWN0
Whirlpool LE8650XWW0
Whirlpool LE8860XWQ0
Amana LE9002 Dryer - Ele
Amana LE9012 Washer - Top Loading
Whirlpool LE9100XTN0
Whirlpool LE9100XTN1
Whirlpool LE9100XTW0
Whirlpool LE9100XTW1
Amana LE9107W Dryer - Ele
Whirlpool LE9200XWN0
Whirlpool LE9200XWN1
Whirlpool LE9200XWW0
Whirlpool LE9200XWW1
Amana LE9207L2 Dryer - Ele
Amana LE9207W Dryer - Ele
Amana LE9207W2 Dryer - Ele
Whirlpool LE9300XTN0
Whirlpool LE9300XTN1
Whirlpool LE9300XTW0
Whirlpool LE9300XTW1
Whirlpool LE9380XTN0
Whirlpool LE9380XTW0
Whirlpool LE9480XWG1
Whirlpool LE9480XWN0
Whirlpool LE9480XWN1
Whirlpool LE9480XWW0
Whirlpool LE9480XWW1
Whirlpool LE9500XTF0
Whirlpool LE9500XTG0
Whirlpool LE9500XTG1
Whirlpool LE9500XTM0
Whirlpool LE9500XTN0
Whirlpool LE9500XTN1
Whirlpool LE9500XTW0
Whirlpool LE9500XTW1
Whirlpool LE9520XTW0
Whirlpool LE9520XTW1
Whirlpool LE9680XWG1
Whirlpool LE9680XWN0
Whirlpool LE9680XWN1
Whirlpool LE9680XWW0
Whirlpool LE9680XWW1
Whirlpool LE9800XKW0
Whirlpool LE9800XKW1
Whirlpool LE9800XMW0
Whirlpool LE9800XMW1
Whirlpool LE9800XMW2
Whirlpool LE9800XPF1
Whirlpool LE9800XPG1
Whirlpool LE9800XPM1
Whirlpool LE9800XPN1
Whirlpool LE9800XPT1
Whirlpool LE9800XPW0
Whirlpool LE9800XPW1
Whirlpool LE9800XSW0
Whirlpool LE9805XPW0
Amana LEA10AW Dryer - Ele
Amana LEA20AL Dryer - Ele
Amana LEA20AW Dryer - Ele
Amana LEA30AL Dryer - Ele
Amana LEA30AW Dryer - Ele
Amana LEA50AL Dryer - Ele
Amana LEA50AW Dryer - Ele
Amana LEA60AL Dryer - Ele
Amana LEA60AW Dryer - Ele
Amana LEA80AL Dryer - Ele
Amana LEA80AW Dryer - Ele
Amana LEA90AL Dryer - Ele
Amana LEA90AW Dryer - Ele
General Electric LEB116GR1AD Electric range
General Electric LEB116GR1WH Electric range
General Electric LEB116GT1AD Electric range
General Electric LEB116GT1WH Electric range
General Electric LEB116GT2AD Electric range
General Electric LEB116GT2WH Electric range
General Electric LEB131GR1AD Electric range
General Electric LEB131GR1WH Electric range
General Electric LEB131GT1AD Electric range
General Electric LEB131GT1WH Electric range
General Electric LEB131GT2AD Electric range
General Electric LEB131GT2WH Electric range
General Electric LEB131GY1AD Electric range
General Electric LEB131GY1WH Electric range
General Electric LEB131GY2AD Electric range
General Electric LEB131GY2WH Electric range
General Electric LEB133GS1WW Electric range
General Electric LEB316GR1AD Electric range
General Electric LEB316GR1WH Electric range
General Electric LEB316GT1AD Electric range
General Electric LEB316GT1WH Electric range
General Electric LEB316GT2AD Electric range
General Electric LEB316GT2WH Electric range
General Electric LEB316GT3AD Electric range
General Electric LEB316GT3WH Electric range
  #2 (permalink)
Old 07-01-2010, 08:30 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
I cannot find a wiring diagram for this unit so can olny give general info.
Won't run.....
I am assuming that the motor will not start.
The only device in the heating area that will stop the motor from running is the thermal fuse usually mounted on the blower assembly.
Have you tried flipping the breaker off/on a couple times. Sometimes you can loose half the line or Neutral without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
Other things to check would be the door switch and the push-to-start switch.
When you replaced it did you clean/check the vent system and the blower wheel.
Something cause it to go a second time.
If yes then it could be your motor was going south, running slower and the lower air flow blew the thermal fuse. Perhaps it has finally given up the ghost.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
amana gas dryer mtkk Dryer Repair 0 05-04-2010 05:20 AM
Amana Dryer jdrake97 Dryer Repair 1 10-16-2009 05:37 AM
Amana Dryer Benda9 Dishwasher Repair 1 09-29-2009 02:54 PM
Amana Dryer ldaniels@abog.org Dryer Repair 1 02-18-2009 05:34 PM
Amana dryer gas augie0629 Dryer Repair 1 12-16-2007 06:55 PM
