Discuss
Dryer Fan
 in
Dryer Repair
Should the fan cage "spin freely" on the motor shaft or should it rotate 1 to 1 with the motor
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer Fan
  #1 (permalink)
Old 06-30-2010, 08:29 AM
Junior Member
dittypro is on a distinguished road
Default Dryer Fan
Model Number: LDE312   Brand: Maytag   Age: More than 10 years
Should the fan cage "spin freely" on the motor shaft or should it rotate 1 to 1 with the motor shaft. Is there a "flat spot" on the inner surface of fan hole?
also: are there any NEW fans that have the exact profile of the fan that came with the dryer? In the replacement "kits' I see out there the fan blades are not curved and the BACKS do not have the nice RADIUS that the OEM fan does.
I want replacement parts equal to the original equipment that came with this dryer. Where do we find them?
dittypro.
Related Models
Maytag LDE312 DRYER- ELE
Maytag LDE313 DRYER- ELE
Frigidaire LDE333PBW0 Frg(v0) / Gas Dryer
Frigidaire LDE333PBW1 Frg(v0) / Electric Dryer
Frigidaire LDE333PEW0 Frg(v0) / Electric Dryer
Maytag LDE382 DRYER- ELE
Maytag LDE4000 DRYER- ELE
Maytag LDE4000ACL DRYER- ELE
Maytag LDE4000ACW DRYER- ELE
Maytag LDE4000ADL DRYER- ELE
Maytag LDE4000ADW DRYER- ELE
Maytag LDE410 DRYER- ELE
Maytag LDE412 DRYER- ELE
Maytag LDE482 DRYER- ELE
Maytag LDE490 DRYER- ELE
Maytag LDE4910 DRYER- ELE
Maytag LDE4910ACL DRYER- ELE
Maytag LDE4910ACW DRYER- ELE
Maytag LDE4914ACE DRYER- ELE
Maytag LDE4914ACL DRYER- ELE
Maytag LDE4914ACM DRYER- ELE
Maytag LDE4916ACE DRYER- ELE
Maytag LDE4916ACM DRYER- ELE
Maytag LDE4916ADE DRYER- ELE
Maytag LDE5004ACW DRYER- ELE
Maytag LDE5004ADW DRYER- ELE
Maytag LDE5005ACE DRYER- ELE
Maytag LDE5005ADE DRYER- ELE
Maytag LDE510 DRYER- ELE
Maytag LDE512 DRYER- ELE
Maytag LDE590 DRYER- ELE
Maytag LDE590D DRYER- ELE
Maytag LDE5910 DRYER- ELE
Maytag LDE5910ACL DRYER- ELE
Maytag LDE5910ACW DRYER- ELE
Maytag LDE5914ACE DRYER- ELE
Maytag LDE5914ACL DRYER- ELE
Maytag LDE5914ACM DRYER- ELE
Maytag LDE5916ACE DRYER- ELE
Maytag LDE5916ACM DRYER- ELE
Maytag LDE5916ADE DRYER- ELE
Maytag LDE6004ACW DRYER- ELE
Maytag LDE610 DRYER- ELE
Maytag LDE612 DRYER- ELE
Maytag LDE6914ACE DRYER- ELE
Maytag LDE6914ACL DRYER- ELE
Maytag LDE6914ACM DRYER- ELE
Maytag LDE710 DRYER- ELE
Maytag LDE712 DRYER- ELE
Maytag LDE713 DRYER- ELE
Maytag LDE7304ACE DRYER- ELE
Maytag LDE7304ACL DRYER- ELE
Maytag LDE7304ACM DRYER- ELE
Maytag LDE7304ADE DRYER- ELE
Maytag LDE7304ADL DRYER- ELE
Maytag LDE7304ADM DRYER- ELE
Maytag LDE7304AEE DRYER- ELE
Maytag LDE7304AGE DRYER- ELE
Maytag LDE7304AGL DRYER- ELE
Maytag LDE7304AGM DRYER- ELE
Maytag LDE7314ACE DRYER- ELE
Maytag LDE7314ACL DRYER- ELE
Maytag LDE7314ACM DRYER- ELE
Maytag LDE7314ADE DRYER- ELE
Maytag LDE7334ACE DRYER- ELE
Maytag LDE7334ACL DRYER- ELE
Maytag LDE7334ACM DRYER- ELE
Maytag LDE7400 DRYER- ELE
Maytag LDE7400ACL DRYER- ELE
Maytag LDE7400ACM DRYER- ELE
Maytag LDE7400ACW DRYER- ELE
Maytag LDE7400ADL DRYER- ELE
Maytag LDE7400ADW DRYER- ELE
Maytag LDE7480ACL DRYER- ELE
Maytag LDE7480ACW DRYER- ELE
Maytag LDE7480ADL DRYER- ELE
Maytag LDE7480ADW DRYER- ELE
Maytag LDE7500 DRYER- ELE
Maytag LDE7500ACE DRYER- ELE
Maytag LDE7500ACL DRYER- ELE
Maytag LDE7500ACM DRYER- ELE
Maytag LDE7500ACW DRYER- ELE
Maytag LDE7500ADE DRYER- ELE
Maytag LDE7500ADL DRYER- ELE
Maytag LDE7500ADM DRYER- ELE
Maytag LDE7500ADW DRYER- ELE
Maytag LDE7600 DRYER- ELE
Maytag LDE7600ACG DRYER- ELE
Maytag LDE7600ACL DRYER- ELE
Maytag LDE7600ACW DRYER- ELE
Maytag LDE7600ADL DRYER- ELE
Maytag LDE7600ADW DRYER- ELE
Maytag LDE7600AGG DRYER- ELE
Maytag LDE7600AGL DRYER- ELE
Maytag LDE7600AGW DRYER- ELE
Maytag LDE7800 DRYER- ELE
Maytag LDE7800ACL DRYER- ELE
Maytag LDE7800ACW DRYER- ELE
Maytag LDE7800ADL DRYER- ELE
Maytag LDE7800ADW DRYER- ELE
Maytag LDE8000 DRYER- ELE
Maytag LDE8000ACL DRYER- ELE
Maytag LDE8000ACW DRYER- ELE
Maytag LDE8000ADL DRYER- ELE
Maytag LDE8000ADW DRYER- ELE
Maytag LDE810 DRYER- ELE
Maytag LDE8200 DRYER- ELE
Maytag LDE8200ACE DRYER- ELE
Maytag LDE8200ACL DRYER- ELE
Maytag LDE8200ACW DRYER- ELE
Maytag LDE8200ADE DRYER- ELE
Maytag LDE8200ADL DRYER- ELE
Maytag LDE8200ADW DRYER- ELE
Maytag LDE8300 DRYER- ELE
Maytag LDE8300ACL DRYER- ELE
Maytag LDE8300ACW DRYER- ELE
Maytag LDE8304ACE DRYER- ELE
Maytag LDE8304ACL DRYER- ELE
Maytag LDE8304ACM DRYER- ELE
Maytag LDE8404ACE DRYER- ELE
  #2 (permalink)
Old 06-30-2010, 12:13 PM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for LDE312 models | AppliancePartsPros.com
See section 5
Yes the fan blade should have a flat spot and be solid on the motor's shaft.
__________________
  #3 (permalink)
Old 06-30-2010, 06:44 PM
Junior Member
Default dryer fan
so... you refuse to comment on quality of the fan you're offering. I can see that they are simplified, nylon fan that will not move air as efficiently as OEM fan.
RK Galloway
  #4 (permalink)
Old 07-01-2010, 03:24 AM
Senior Expert
APP Volunteer
Default
No, I do not refuse to comment on anything but then I do not work for AppliancePartsPros. This is an open forum which they kindly sponsor.
If you want specific comments from AppliancePartsPros, I would contact them directly.
This is an approved replacement as that is all AppliancePartsPros sells so it should push the required CFM. Also if the original was such a great part, why does it need replacing.
__________________
  #5 (permalink)
Old 07-01-2010, 07:06 AM
Junior Member
Default dryer part
The replacement fan you're recommending would be noisy compared to contoured fan. "required CFM" is like national health care for every one.... you get the minimum requirement. We'll repair the existing fan with a steel collar and set screw instead of depending on friction and weak "clip" solution provided.
Should there be ceramic bearing supporting the clothes tumbler? I found what looked like "1/2" of a ceramic ring of some sort... apx. 3/8 in. in diameter in the bottom of the dryer case. Seems reasonable that there would be bearings of some sort supporting the tumbler which is now a rumbler.
rk
  #6 (permalink)
Old 07-01-2010, 08:17 AM
Senior Expert
APP Volunteer
Default
I am a Canuck and have national health care.
Your "minimum requirement" statement tells me you know nothing about our system, hopefully you have more dryer knowledge.
Sounds like a plan but if you do not get it perfectly balanced you will screw up your motor's bearing.
No.
Could be the following or an element support from inside the heater.
Part number: AP4290688
Rear of drum is supported by rubber rollers with oilite brass bearings. They are often the cause of a rumble re: rubber is out of round or the bearing is toast.
Front of drum is supported by plastic glide strips, usually starts screeching or grinding when they wear out.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer won't heat and I don't know how to take the back cover of the dryer off to chec dcwike Dryer Repair 2 11-25-2009 07:40 AM
bad dryer owner breaks dryer with good intentions. arcadeforever Dryer Repair 6 04-17-2009 09:28 AM
Gas Dryer tumbles but won't heat. Timer does not move when dryer is started. NEAL AMES Dryer Repair 1 01-02-2009 06:40 PM
coin op dryer timer starts but dryer doesn't turn on Mike Craw Dryer Repair 4 01-10-2008 07:26 PM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 10:47 AM
