Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   Dryer not heating (http://forum.appliancepartspros.com/dryer-repair/103797-dryer-not-heating.html)
Dominic l 06-30-2010 06:08 AM
Dryer not heating
My dryer runs it just does not heat someone please help,how do i trouble shoot this situation?Thanks Dominic
denman 07-01-2010 08:56 AM
Replacement parts for WHIRLPOOL REX5634PQ0 29" Electric Dryer | AppliancePartsPros.com
Here is a wiring diagram
http://www.servicematters.com/docs/w...%208528187.pdf
Whirlpool makes most Ropers.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
Next check the thermostats and thermal fuse.
All should be 0 ohms.
If the thermal fuse by the heater is blown you have to find out what caused it to go.
Note: that sometimes they do just blow on their own but changing it without checking other things is a gamble. I believe richappy (another regular poster on this forum) has done a study on thermostats and found a wide variation of actual trip point and what is specified.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
If the above is OK then you will also have to replace the hi-limit as it should have regulated the temperature so the fuse did not blow.
You still have to find out why it blew.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut).
Here is a good site with general troubleshooting help
http://www.applianceaid.com/dryers.html
