Discuss
Kenmore Ultra Fabric Care Dryer (gas) won't spin
 in
Dryer Repair
The dryer will make a low buzz when the starter button is pressed, but it does not spin. I was
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore Ultra Fabric Care Dryer (gas) won't spin
  #1 (permalink)
Old 06-29-2010, 02:45 PM
Junior Member
tdmbulk is on a distinguished road
Thumbs down Kenmore Ultra Fabric Care Dryer (gas) won't spin
Model Number: 110.87983100   Brand: Kenmore   Age: More than 10 years
The dryer will make a low buzz when the starter button is pressed, but it does not spin. I was not there, but apparently the dryer was functioning normally, then all of a sudden got much louder. Upon inspection, the drum wasn't spinning, and the air and drum were hotter than normal.
I opened up the beast, shop-vacuumed the lint bunnies away, and examined the insides. The belt appears to be integral, with no splits or fraying. I can pull the belt one-handed to spin the drum, so it appears that the belt and rollers are at least functioning, albeit not functioning optimally after 15 years of laundry rolling through.
When the button is pushed, I do not feel nor see any attempt to move the belt, just a buzzing noise. Bearings in the motor could be shot, I suppose.
I would consider replacing parts such as the motor, belts, rollers, etc., but don't want to put a couple hundred into this dinosaur; would rather get a new one and hope to live long enough to take the energy savings into the black.
Anybody have any more advanced ways of checking the belts, rollers, etc., or is the fact that I can manually spin the drum with the belt sufficient to rule those parts out?
Ads By Google
Related Models
Kenmore 110.92490100  GAS DRYER
Kenmore 110.92822100  GAS DRYER
Kenmore 110.92822101  GAS DRYER
Kenmore 110.92822102  GAS DRYER
Kenmore 110.92824100  GAS DRYER
Kenmore 110.92824101  GAS DRYER
Kenmore 110.92824102  GAS DRYER
Kenmore 110.92826100  GAS DRYER
Kenmore 110.92826101  GAS DRYER
Kenmore 110.92826102  GAS DRYER
Kenmore 110.92832100  DRYER
Kenmore 110.92834100  DRYER
Kenmore 110.92836100  DRYER
Kenmore 110.94832200  GAS DRYER
Kenmore 110.94832201  GAS DRYER
Kenmore 110.94834200  GAS DRYER
Kenmore 110.94834201  GAS DRYER
Kenmore 110.94836200  GAS DRYER
Kenmore 110.94836201  GAS DRYER
Kenmore 110.96060100  ELECTRIC DRYER
Kenmore 110.96091100  ELECTRIC DRYER
Kenmore 110.96091300  ELECTRIC DRYER
Kenmore 110.96091700  ELECTRIC DRYER
Kenmore 110.96091800  ELECTRIC DRYER
Kenmore 110.96093100  ELECTRIC DRYER
Kenmore 110.96093300  ELECTRIC DRYER
Kenmore 110.96093500  ELECTRIC DRYER
Kenmore 110.96093700  ELECTRIC DRYER
Kenmore 110.96093800  ELECTRIC DRYER
Kenmore 110.96094100  ELECTRIC DRYER
Kenmore 110.96094300  ELECTRIC DRYER
Kenmore 110.96094500  ELECTRIC DRYER
Kenmore 110.96094700  ELECTRIC DRYER
Kenmore 110.96094800  ELECTRIC DRYER
Kenmore 110.96110100  ELECTRIC DRYER
Kenmore 110.96121100  ELECTRIC DRYER
Kenmore 110.96195100  ELECTRIC DRYER
Kenmore 110.96195110  DRYER FEATURE SHEET
Kenmore 110.96407160  COMMERCIAL ELECTRIC DRYER
Kenmore 110.97502120  GAS DRYER-COMMERCIAL
Kenmore 110.97502820  GAS DRYER-COMMERCIAL
Kenmore 110.97565120  GAS DRYER
Kenmore 110.97565220  GAS DRYER
Hoover 1100
Magic Chef 1100PAA Range - F/s Std Gas
Magic Chef 1100PAW Range - F/s Std Gas
Magic Chef 1100PAW-K Range - F/s Std Gas
Magic Chef 1100PAW-KL Range - F/s Std Gas
Magic Chef 1100PAW-L Range - F/s Std Gas
Magic Chef 1100PRA Range - F/s Std Gas
Magic Chef 1100PRA-K Range - F/s Std Gas
Magic Chef 1100PRW Range - F/s Std Gas
Magic Chef 1100PRW-K Range - F/s Std Gas
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Sears 11016502693 AUTOMATIC WASHER
Sears 11016502694 AUTOMATIC WASHER
Sears 11016512691 AUTOMATIC WASHER
Sears 11016512692 AUTOMATIC WASHER
Sears 11016602690 AUTOMATIC WASHER
Sears 11016602691 AUTOMATIC WASHER
Sears 11016602692 AUTOMATIC WASHER
Sears 11016602693 AUTOMATIC WASHER
Sears 11016611690 AUTOMATIC WASHER
Sears 11016611691 AUTOMATIC WASHER
Sears 11016611692 AUTOMATIC WASHER
Sears 11016612690 AUTOMATIC WASHER
Sears 11016612691 AUTOMATIC WASHER
Sears 11016612692 AUTOMATIC WASHER
Sears 11016872691 AUTOMATIC WASHER
Sears 11016872692 AUTOMATIC WASHER
Sears 11016872693 AUTOMATIC WASHER
Sears 11018542890 AUTOMATIC WASHER
Hoover 1102
Kenmore 11020052994 WASHER
Kenmore 11020056991 WASHER
Kenmore 11020056992 WASHER
Kenmore 11020056994 WASHER
Kenmore 11020072990 WASHER
Kenmore 11020072991 WASHER
Kenmore 11020072992 WASHER
Kenmore 11020072993 WASHER
Kenmore 11020092990 WASHER
Kenmore 11020092991 WASHER
Kenmore 11020092992 WASHER
Kenmore 11020092993 WASHER
Kenmore 11020094992 WASHER
Kenmore 11020094993 WASHER
Kenmore 11020096990 WASHER
Kenmore 11020096991 WASHER
Kenmore 11020096992 WASHER
Kenmore 11020096993 WASHER
Kenmore 11020097990 WASHER
Kenmore 11020097991 WASHER
Kenmore 11020097992 WASHER
Kenmore 11021062000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021062001 WASHER
Kenmore 11021064000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021064001 WASHER
Kenmore 11021066000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021066001 WASHER
Kenmore 11021082000 WASHER
Kenmore 11021082001 WASHER
Kenmore 11021084000 WASHER
Kenmore 11021084001 WASHER
Kenmore 11021086000 WASHER
Kenmore 11021086001 WASHER
Kenmore 11021882000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021882001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021892000 WASHER
Kenmore 11021894000 WASHER
Kenmore 11022032100 WASHER
Kenmore 11022032101 WASHER
Kenmore 11022032102 AUTOMATIC WASHER
Kenmore 11022036100 WASHER
Kenmore 11022036101 WASHER
Kenmore 11022036102 AUTOMATIC WASHER
Kenmore 11022042100 WASHER
  #2 (permalink)
Old 06-30-2010, 09:01 PM
Junior Member
Default
I'm taking the whole darn thing apart tonight; should be either the solution or a funeral service soon.
  #3 (permalink)
Old 07-01-2010, 11:31 AM
Junior Member
Default
Quote:
Turns out a sock somehow managed to get into the motor housing and jam things up. Apparently at one point the dryer was run without the lint filter installed at all, and the sock eventually migrated into the motor area. After removal, the dryer is back to working, and is much cleaner to boot.
  #4 (permalink)
Old 07-01-2010, 02:23 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Just wanted to say thank you for sharing your diagnosis and repair with us. It is not often we see a sock in the motor housing, so your post was very illuminating and instructive.
Good luck with your dryer.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
lady kenmore ultra fabric care electric dryer wont turn on John414 Dryer Repair 2 03-07-2010 06:44 AM
Kenmore Elctronic Fabric Care old school JoeCone Dryer Repair 0 01-26-2010 08:53 AM
Kenmore Ultra Fabric Care willing303 Washer Repair 1 07-13-2009 01:05 PM
Kenmore Ultra Fabric Care series 80 Clogged Filter CrystalRansom Washer Repair 0 03-02-2009 06:34 PM
Kenmore Ultra Fabric Care Dryer anniesmomrocks Dryer Repair 3 02-16-2009 01:06 PM
