Discuss
Gas dryer
 in
Dryer Repair
Dryer's burner will light and burn for several minutes producing hot air. Then after several minutes the burner will
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Gas dryer
  #1 (permalink)
Old 07-29-2008, 05:55 AM
nelsonhutchins nelsonhutchins is offline
Junior Member
nelsonhutchins is on a distinguished road
Default Gas dryer
Model Number: lg5701xkw0   Brand: Whirlpool   Age: 5 - 10 years
Dryer's burner will light and burn for several minutes producing hot air. Then after several minutes the burner will cycle off and only produce warm air. Then the burner will again light and burn for several minutes again producing hot air. The dryer takes several hours to dry a load of clothes. Have checked thermostats and all three read continuity on an ohmmeter. The thermal fuse also has continuity and is not blown. Is my problem the gas valve coils or is one of the thermostats opening up prematurely???
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
