Discuss
Clothes Dryer blows heater fuse
 in
Dryer Repair
The blown device is located on the air chute and close to the hot air outlet. I replaced it and
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Clothes Dryer blows heater fuse
  #1 (permalink)
Old 06-25-2010, 06:04 PM
Junior Member
William Gravett is on a distinguished road
Question Clothes Dryer blows heater fuse
Model Number: LE5705XPW1   Brand: Whirlpool   Age: More than 10 years
The blown device is located on the air chute and close to the hot air outlet. I replaced it and the device close to the bottom of the chute once back in April. Worked fine for a bout 6 weeks then the device at the top blew again.
The resistance across the heater element is 10.8 ohms....in spec. As far as I can tell the exhaust line is clear.
Was thinking that after multiple drying sessions at high heat setting, maybe allowing system to cool for say a half hour or so before starting up another load would help the problem. Any help would be appreciated.
Related Models
Whirlpool LE5705XPW1 Residential Dryer
Whirlpool LE5720XPW0 Residential Dryer
Whirlpool LE5720XSW0 Residential Dryer
Whirlpool LE5720XSW1 Residential Dryer
Whirlpool LE5725XPW0 Residential Dryer
Whirlpool LE5750XKW0 Residential Dryer
Whirlpool LE5750XKW1 Residential Dryer
Whirlpool LE5750XKW2 Residential Dryer
Whirlpool LE5750XMW0 Residential Dryer
Whirlpool LE5750XMW1 Residential Dryer
Whirlpool LE5760XSW0 Residential Dryer
Whirlpool LE5760XSW1 Residential Dryer
Whirlpool LE5770XWW0 Residential Dryer
Whirlpool LE5780XKW0 Residential Dryer
Whirlpool LE5780XKW1 Residential Dryer
Whirlpool LE5780XMW0 Residential Dryer
Whirlpool LE5780XMW1 Residential Dryer
Whirlpool LE5780XMW2 Residential Dryer
Whirlpool LE5790XMW0 Residential Dryer
Whirlpool LE5790XMW1 Residential Dryer
Whirlpool LE5790XPW0 Residential Dryer
Whirlpool LE5790XSW0 Residential Dryer
Whirlpool LE5790XSW1 Residential Dryer
Whirlpool LE5795XMW0 Residential Dryer
Whirlpool LE5795XPW0 Residential Dryer
Whirlpool LE5795XPW1 Residential Dryer
Whirlpool LE5800XKW0 DRYER
Whirlpool LE5800XKW1 Residential Dryer
Whirlpool LE5800XMW0 Residential Dryer
Whirlpool LE5800XMW1 Residential Dryer
Whirlpool LE5800XMW2 Residential Dryer
Whirlpool LE5800XPW0 Residential Dryer
Whirlpool LE5800XPW1 Residential Dryer
Whirlpool LE5800XSN3 ELECTRIC DRYER
Whirlpool LE5800XSW0 Residential Dryer
Whirlpool LE5800XSW1 Residential Dryer
Whirlpool LE5800XSW2 Residential Dryer
Whirlpool LE5800XSW3 Residential Dryer
Whirlpool LE5805XPW0 Residential Dryer
Whirlpool LE5810XPW0 Residential Dryer
Whirlpool LE5900XSW0 Residential Dryer
Whirlpool LE5920XKW0 Residential Dryer
Whirlpool LE5920XKW1 Residential Dryer
Whirlpool LE5920XMW0 Residential Dryer
Whirlpool LE5920XMW1 Residential Dryer
Whirlpool LE5920XMW2 Residential Dryer
Whirlpool LE5950XSW0 Residential Dryer
Frigidaire LE600AXD1 Wwh(v2) / 27 " Laundry Center
Frigidaire LE600AXD2 Wwh(v2) / 27 " Laundry Center
Frigidaire LE600AXW1 Wwh(v1) / 27 " Laundry Center
Frigidaire LE600AXW2 Wwh(v1) / 27 " Laundry Center
Frigidaire LE600MXD1 Wwh(v2) / 27 " Laundry Center
Frigidaire LE600MXD2 Wwh(v2) / 27 " Laundry Center
Frigidaire LE600MXD3 Wwh(v2) / 27 " Laundry Center
Frigidaire LE600MXW1 Wwh(v1) / 27 " Laundry Center
Frigidaire LE600MXW2 Wwh(v1) / 27 " Laundry Center
Frigidaire LE600MXW3 Wwh(v1) / 27 " Laundry Center
Whirlpool LE6055XSW0 Residential Dryer
Whirlpool LE6055XSW1 Residential Dryer
Whirlpool LE6090XSW0 Residential Dryer
Whirlpool LE6090XSW1 Residential Dryer
Whirlpool LE6090XTW0 Residential Dryer
Whirlpool LE6098XSW0 Residential Dryer
Whirlpool LE6098XSW1 Residential Dryer
Whirlpool LE6098XTW0 Residential Dryer
Whirlpool LE6098XTW1 Residential Dryer
Whirlpool LE6100XSW0 Residential Dryer
Whirlpool LE6150XSW0 Residential Dryer
Whirlpool LE6150XSW1 Residential Dryer
Whirlpool LE6400XKW0 Residential Dryer
Whirlpool LE6400XPW0 Residential Dryer
Whirlpool LE6400XSW0 Residential Dryer
Whirlpool LE6405XPW0 Residential Dryer
Whirlpool LE6600XPW0 Residential Dryer
Whirlpool LE6600XSW0 Residential Dryer
Whirlpool LE6605XPW0 Residential Dryer
Whirlpool LE6605XPW1 Residential Dryer
Whirlpool LE6680XPW0 Residential Dryer
Whirlpool LE6680XSW0 Residential Dryer
Whirlpool LE6685XPW0 Residential Dryer
Whirlpool LE6685XPW1 Residential Dryer
Whirlpool LE6800XPW0 Residential Dryer
Whirlpool LE6800XSW0 Residential Dryer
Whirlpool LE6800XTG0
Whirlpool LE6800XTN0
Whirlpool LE6800XTW0 Residential Dryer
Whirlpool LE6805XPW0 Residential Dryer
Whirlpool LE6810XPW0 Residential Dryer
Whirlpool LE6810XSW0 Residential Dryer
Whirlpool LE6880XSW0 Residential Dryer
Whirlpool LE6880XSW1 Residential Dryer
Whirlpool LE6880XTW0 Residential Dryer
Whirlpool LE6880XTW1 Residential Dryer
Whirlpool LE7000XMW0 Residential Dryer
Whirlpool LE7000XMW1 Residential Dryer
Whirlpool LE7000XMW2 Residential Dryer
Whirlpool LE7000XPW0 Residential Dryer
Whirlpool LE7000XSW0 Residential Dryer
Whirlpool LE7000XTG0
Whirlpool LE7000XTN0
Whirlpool LE7000XTW0 Residential Dryer
Whirlpool LE7005XPW0 Residential Dryer
Whirlpool LE7010XPW0 Residential Dryer
Whirlpool LE7010XSW0 Residential Dryer
Whirlpool LE7080XSW0 Residential Dryer
Whirlpool LE7080XSW1 Residential Dryer
Whirlpool LE7080XTW0 Residential Dryer
Whirlpool LE7080XTW1 Residential Dryer
Amana LE7101LB DRYER- ELE
Amana LE7101WB DRYER- ELE
Amana LE7111LB DRYER- ELE
Amana LE7111LM DRYER- ELE
Amana LE7111WB DRYER- ELE
Amana LE7111WM DRYER- ELE
Amana LE7121LM DRYER- ELE
Amana LE7121WM DRYER- ELE
Amana LE7153LB DRYER- ELE
Amana LE7153LM DRYER- ELE
Amana LE7153WB DRYER- ELE
Amana LE7153WM DRYER- ELE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer blows fuse fradycosmo Dryer Repair 1 08-31-2009 04:27 PM
dryer blows house fuse patroler5 Dryer Repair 1 08-24-2009 11:23 AM
How to find the fuse of a GE clothes gas dryer? yzhong Dryer Repair 0 07-20-2009 03:31 PM
dryer overheats, blows thermal fuse netsteeler Dryer Repair 7 06-03-2009 10:08 AM
Dryer Fuse Blows Often AL RYF Dryer Repair 1 06-24-2008 02:57 PM
