| » GE Dryer runs but won't heat |
Model Number: dx4500ga2ww Brand: GE Age: 5 - 10 years
This dryer runs but will not heat. I was having a problem with the start switch so I replaced that. Still no heat. There are about 4 different parts that I know of that might cause this problem: (1) main timer (2) heat sensor (3)thermostat (4) igniter and maybe more that I don't know about. How can I test these parts to find out which one is bad? To buy one part at a time to find out which one is bad would put me in the poor-house and I don't have that kind of money to spend. Any help you could provide would be greatly appreciated.
You have to have a simple multimeter to perform troubleshooting. Most of electrical parts in your dryer have to be tested for continuity.
Here are the break down diagrams for the GE dryer Model DX4500GA2WW Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Quote:
__________________
yancecra,
Can you be more specific on the problem? What is the complete model number of the dryer? Gene.
__________________
My GE dryer started working enough to dry 4 loads of clothes. I have not replaced any other parts except the start switch which I mentioned in my first post. The problem now and has been is the start switch does not always turn the dryer on without turning the knob back and forth a few times. When I do get it to run its seems to work normally. I have been told that the ignitor is either good or bad. no in-between. Is this true of ignitors? What could be the problem of the start switch not always turning the dryer on? I'm stumped again!
The start switch has nothing to do with the igniter.
Did the dryer make any noise when you tried to start it and it did not start? Gene.
__________________
Dryer did not make any noise when I tried to start it and it didn't start.(no noise at all, it just didn't start) I just went out and tried it again. Start switch worked this time and the drying cycle started like it's suppose to. Thats great but I can't depend on it happening every time like it's suppose to.
| Display Modes | |
| Dryer runs, but no heat | bluky | Dryer Repair | 1 | 12-21-2009 02:36 AM |
| Clothes dryer runs, but doest not heat (Dryer no heat | yzhong | Dryer Repair | 5 | 10-29-2009 04:54 PM |
| dryer runs no heat | Jim Bags | Dryer Repair | 1 | 09-01-2009 05:23 AM |
| Gas dryer runs but won't heat | sblack | Dryer Repair | 1 | 10-07-2008 02:41 AM |
| Dryer runs no heat | glennb | Dryer Repair | 1 | 08-10-2007 10:24 AM |
