Discuss
GE Dryer runs but won't heat
 in
Dryer Repair
This dryer runs but will not heat. I was having a problem with the start switch so I replaced that.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » GE Dryer runs but won't heat
  #1 (permalink)
Old 07-25-2008, 05:12 PM
JWG JWG is offline
Junior Member
JWG is on a distinguished road
Default GE Dryer runs but won't heat
Model Number: dx4500ga2ww   Brand: GE   Age: 5 - 10 years
This dryer runs but will not heat. I was having a problem with the start switch so I replaced that. Still no heat. There are about 4 different parts that I know of that might cause this problem: (1) main timer (2) heat sensor (3)thermostat (4) igniter and maybe more that I don't know about. How can I test these parts to find out which one is bad? To buy one part at a time to find out which one is bad would put me in the poor-house and I don't have that kind of money to spend. Any help you could provide would be greatly appreciated.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-26-2008, 03:35 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
You have to have a simple multimeter to perform troubleshooting. Most of electrical parts in your dryer have to be tested for continuity.
Here are the break down diagrams for the GE dryer Model DX4500GA2WW
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 07-26-2008, 08:01 PM
JWG JWG is offline
Junior Member
Default
I do have a multimeter. I checked the igniter leads and found the following:There is no continunity between the two leads coming from igniter. In fact, on the ohms scale it read 20.8 M ohm. On the continunity setting it read OL, or overload. Does this tell me the igniter is probably bad, or good? Thanks
  #4 (permalink)
Old 07-26-2008, 08:56 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Most likely the problem is a bad igniter.
- The part number for the igniter is AP2042786
__________________
  #5 (permalink)
Old 07-28-2008, 10:56 AM
yancecra yancecra is offline
Junior Member
yancecra is on a distinguished road
Default white-westinghouse dryer
The dryer i have will not get hot
  #6 (permalink)
Old 07-30-2008, 06:24 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
yancecra,
Can you be more specific on the problem?
What is the complete model number of the dryer?
__________________
  #7 (permalink)
Old 07-31-2008, 04:56 PM
JWG JWG is offline
Junior Member
Default
My GE dryer started working enough to dry 4 loads of clothes. I have not replaced any other parts except the start switch which I mentioned in my first post. The problem now and has been is the start switch does not always turn the dryer on without turning the knob back and forth a few times. When I do get it to run its seems to work normally. I have been told that the ignitor is either good or bad. no in-between. Is this true of ignitors? What could be the problem of the start switch not always turning the dryer on? I'm stumped again!
  #8 (permalink)
Old 07-31-2008, 07:12 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The start switch has nothing to do with the igniter.
Did the dryer make any noise when you tried to start it and it did not start?
__________________
  #9 (permalink)
Old 07-31-2008, 07:40 PM
JWG JWG is offline
Junior Member
Default
Dryer did not make any noise when I tried to start it and it didn't start.(no noise at all, it just didn't start) I just went out and tried it again. Start switch worked this time and the drying cycle started like it's suppose to. Thats great but I can't depend on it happening every time like it's suppose to.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer runs but will not heat up freezer65 Dryer Repair 0 07-04-2008 01:26 PM
Dryer Runs but no heat Charlied Dryer Repair 0 07-03-2008 06:16 PM
Dryer runs but doesn't heat Junie15 Dryer Repair 4 09-23-2007 10:09 AM
Dryer runs but doesn't heat Jane Dryer Repair 6 08-07-2007 10:01 PM
Dryer runs no heat Wesley Dryer Repair 3 07-28-2007 12:23 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
