Discuss
drier will not heat
 in
Dryer Repair
Drier runs but will not heat. I have replaced the element and this was not the problem. Any suggestions? Ads
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » drier will not heat
  #1 (permalink)
Old 06-22-2010, 08:32 AM
Junior Member
Eric Norrid is on a distinguished road
Default drier will not heat
Model Number: GLER341AS1   Brand: Frigidaire   Age: 5 - 10 years
Ads By Google
Related Models
Frigidaire GLER341AS1 Dryer - Frigidaire Gallery
Frigidaire GLER341AS2 Frigidaire/electric Dryer
Frigidaire GLER341CC0 Frigidaire/dryer
Frigidaire GLER341CDC0 Frigidaire/dryer
Frigidaire GLER341CES0 Frigidaire/dryer
Whirlpool GLER5434BN0 ELECTRIC DRYER
Whirlpool GLER5434BN1 ELECTRIC DRYER
Whirlpool GLER5434BQ1 ELECTRIC DRYER
Whirlpool GLER5434BW0 ELECTRIC DRYER
Whirlpool GLER5434BW1 ELECTRIC DRYER
Frigidaire GLER642AS0 Dryer - Frigidaire Gallery
Frigidaire GLER642AS1 Dryer - Frigidaire Gallery
Frigidaire GLER642AS2 Dryer - Frig Gallery
Frigidaire GLER642AS3 Frigidaire/dryer
Frigidaire GLES388ASA Frigidaire/electric Range
Frigidaire GLES388ASB Frigidaire/electric Range
Frigidaire GLES388ASC Frigidaire/electric Range
Frigidaire GLES388ASD Frigidaire/electric Range
Frigidaire GLES388ASE Frigidaire/electric Range
Frigidaire GLES388CSA Frigidaire/electric Range
Frigidaire GLES388CSB Frigidaire/electric Range
Frigidaire GLES388DBA Frigidaire/electric Range
Frigidaire GLES388DBB Frigidaire/electric Range
Frigidaire GLES388DQA Frigidaire/electric Range
Frigidaire GLES388DQB Frigidaire/electric Range
Frigidaire GLES388DSA Frigidaire/electric Range
Frigidaire GLES388DSB Frigidaire/electric Range
Frigidaire GLES389EBA Frigidaire/electric Range
Frigidaire GLES389EBB Frigidaire/electric Range
Frigidaire GLES389EBC Frigidaire/electric Range
Frigidaire GLES389EBD Frigidaire/electric Range
Frigidaire GLES389EBE Frigidaire/electric Range
Frigidaire GLES389EQA Frigidaire/electric Range
Frigidaire GLES389EQB Frigidaire/electric Range
Frigidaire GLES389EQC Frigidaire/electric Range
Frigidaire GLES389EQD Frigidaire/electric Range
Frigidaire GLES389EQE Frigidaire/electric Range
Frigidaire GLES389ESA Frigidaire/electric Range
Frigidaire GLES389ESB Frigidaire/electric Range
Frigidaire GLES389ESC Frigidaire/electric Range
Frigidaire GLES389ESD Frigidaire/electric Range
Frigidaire GLES389ESE Frigidaire/electric Range
Frigidaire GLES389FBA Frigidaire/electric Range
Frigidaire GLES389FBB Frigidaire/electric Range
Frigidaire GLES389FBC ELECTRIC RANGE
Frigidaire GLES389FBD ELECTRIC RANGE
Frigidaire GLES389FBE ELECTRIC RANGE
Frigidaire GLES389FBF ELECTRIC RANGE
Frigidaire GLES389FQA Frigidaire/electric Range
Frigidaire GLES389FQB Frigidaire/electric Range
Frigidaire GLES389FSA Frigidaire/electric Range
Frigidaire GLES389FSB Frigidaire/electric Range
Frigidaire GLES389FSC ELECTRIC RANGE
Frigidaire GLES389FSD ELECTRIC RANGE
Frigidaire GLES389FSE ELECTRIC RANGE
Frigidaire GLET1031CS0 Frigidaire/laundry Center
Frigidaire GLET1031FS0 Frigidaire/laundry Center
Frigidaire GLET1031FS1 LAUNDRY CENTER
Frigidaire GLET1031FS2 LAUNDRY CENTER
Frigidaire GLET1031FS4 LAUNDRY CENTER
Frigidaire GLET1041AS0 Lc - Frig Gallery
Frigidaire GLET1041AS1 Lc - Frig Gallery
Frigidaire GLET1041AS2 Frigidaire/laundrycenter
Frigidaire GLET1142CS0 Frigidaire/laundry Center
Frigidaire GLET1142FS0 Frigidaire/laundry Center
Frigidaire GLET1142FS1 LAUNDRY CENTER
Frigidaire GLET1142FS2 LAUNDRY CENTER
Frigidaire GLFC1326FW0 Frigidaire/freezer
Frigidaire GLFC1326FW1 Frigidaire/freezer
Frigidaire GLFC1326FW2 FREEZER
Frigidaire GLFC1326FW3 FREEZER
Frigidaire GLFC1526FW0 Frigidaire/freezer
Frigidaire GLFC1526FW1 Frigidaire/freezer
Frigidaire GLFC1526FW2 FREEZER
Frigidaire GLFC1526FW3 FREEZER
Frigidaire GLFC1526FW4 FREEZER
Frigidaire GLFC1526FW5 FREEZER
Frigidaire GLFC1526FW6 FREEZER
Frigidaire GLFC1526FW7 FREEZER
Frigidaire GLFC2027FW0 Frigidaire/freezer
Frigidaire GLFC2027FW1 Frigidaire/freezer
Frigidaire GLFC2027FW2 Frigidaire/freezer
Frigidaire GLFC2027FW3 Frigidaire/freezer
Frigidaire GLFC2027FW4 FREEZER
Frigidaire GLFC2027FW5 FREEZER
Frigidaire GLFC2027FW6 FREEZER
Frigidaire GLFC2528FW0 Frigidaire/freezer
Frigidaire GLFC2528FW1 Frigidaire/freezer
Frigidaire GLFC2528FW10 FREEZER
Frigidaire GLFC2528FW2 Frigidaire/freezer
Frigidaire GLFC2528FW3 Frigidaire/freezer
Frigidaire GLFC2528FW4 FREEZER
Frigidaire GLFC2528FW5 FREEZER
Frigidaire GLFC2528FW6 FREEZER
Frigidaire GLFC2528FW7 FREEZER
Frigidaire GLFC2528FW8 FREEZER
Frigidaire GLFC2528FW9 FREEZER
Frigidaire GLFH1467GW0 FREEZER
Frigidaire GLFH1467GW1 FREEZER
Frigidaire GLFH1767GW1 FREEZER
Frigidaire GLFH1779GW0 FREEZER
Frigidaire GLFH1779GW1 FREEZER
Frigidaire GLFH1779GW2 FREEZER
Frigidaire GLFH17F8HBA FREEZER
Frigidaire GLFH17F8HBB FREEZER
Frigidaire GLFH17F8HBC FREEZER
Frigidaire GLFH17F8HBD FREEZER
Frigidaire GLFH17F8HBF FREEZER
Frigidaire GLFH17F8HBG FREEZER
Frigidaire GLFH17F8HBH FREEZER
Frigidaire GLFH17F8HWA FREEZER
Frigidaire GLFH17F8HWB FREEZER
Frigidaire GLFH17F8HWC FREEZER
Frigidaire GLFH17F8HWD FREEZER
Frigidaire GLFH17F8HWE FREEZER
Frigidaire GLFH17F8HWF FREEZER
Frigidaire GLFH17F8HWG FRIGIDAIRE/FREEZER
Frigidaire GLFH17F8HWH FRIGIDAIRE/FREEZER
Frigidaire GLFH21F8HBA FREEZER
Frigidaire GLFH21F8HBB FREEZER
  #2 (permalink)
Old 06-22-2010, 09:19 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Replacement parts for FRIGIDAIRE GLER341AS1 Dryer - Frigidaire Gallery | AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/prodin.../131850600.pdf
First check that you have the correct power.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
On your unit if the timer advances in Auto modes it is a good indication that the power is OK.
If power is OK then it could be a bad heater (not unheard of to get a bad one out of the box), a bad thermostat (hi-limit or control), bad timer contacts or a bad fabric selector switch. Best to check these with a meter when the unit is unplugged.
Also every once in a while a centrifugal switch on the motor will go bad.
__________________
  #3 (permalink)
Old 06-28-2010, 09:24 AM
Junior Member
dec458 is on a distinguished road
Default Centrifugal Switch On Motor
How do you check to see if the centrifugal switch is bad?
  #4 (permalink)
Old 06-30-2010, 05:03 AM
Senior Expert
APP Volunteer
Default
Best way is a live test.
Be very very careful 240 volts is lethal!!!
You have to connect to L2 and M1 on the motor.
Probably easier to connect to the M1 side of the heater.
With timer at mid-cycle timed dry you should see 240 volts across the switch.
When the motor runs it should drop to 0 volts.
If you do not see 240 with the motor off then something is open from the motor switch to L1.
It is possible to do this with the drum out of the unit but you have to br quick as running the unit without the drum messes up the air flow and you can blow the thermal fuse is left on too long.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Drier Will Not Get Hot DEMENTED1 Dryer Repair 4 06-09-2010 06:07 PM
maytag drier speratic heat grampa munster Dryer Repair 0 12-31-2009 08:50 AM
drier gerri ashjian Dryer Repair 1 09-23-2009 08:17 AM
Inglis heavy duty drier with no heat no model number shestad Dryer Repair 1 06-29-2009 01:03 PM
Drier runs, but no heat jspinelli Dryer Repair 4 06-10-2008 04:12 PM
